06-20-2013, 05:22 AM | #41 |
Re: F1 Front drive shaft yoke
No this is not a "stock" yoke. Its the one the TX shop found for me and is shown in post #10. It is very similar to the one you referred to in post #33. Same barrel length, but 1/8 shorter.
06-23-2013, 11:43 AM | #42 |
I went for a drive in my truck last night, after a monthlong hiatus (out of town). Funny what a fresh perspective does... On a highway with a 55 mph speed limit, as soon as I got above 45 - 50, I could distinctly feel the driveshaft vibrating. Got under there today, I don't see anything wrong. I had the driveshaft balanced < 500 miles ago, all new U-joints. I'll check the pinion and trans angles, that's all I can figure. I measured the as-sitting length of yoke from the face of the seal/trans, it came out at 1-5/8". Yippee, my seal appears to be shot, too...
'52 F-1, EAB flathead |
06-23-2013, 01:48 PM | #43 |
Hi Ross…. Is that a “good” yippee or a “bad” yippee. Attached is my understanding of how an original yoke and transmission mesh together based on the tech info I received from Steve, Ross ,Scott and others. Thanks all very much. Ross your 1-5/8” visible nominal agrees very well with my 1.7”, as I referenced the back of the casting on the transmission rather than the end of the seal.
06-23-2013, 04:23 PM | #44 | |
03-20-2016, 05:14 PM | #45 |
Did anyone get a definite yoke or one that needs shortening for these that are easily available? As I've just picked up one of these boxes and need one. Thanks Harley
12-17-2019, 08:43 PM | #46 | |
https://www.amazon.com/National-7692.../dp/B004A6V072 |
