09-26-2017, 03:45 PM | #41 |
Re: Fuel gauge intermittent
The frustration of trying to make King Sealy units work with the ohms style sending units is not just limited to Fordbarn.
Here are some other thoughts. https://www.ford-trucks.com/forums/1...ce-values.html I tried to measure the resistance of the calibration resistor found inside the KS units and the needle jumped all over the dial. Couldn't get a steady reading. Wonder if it possible to use a tiny variable resistor by wiring it into the KS unit and dialing in the resistance until the gauge responds properly? I also tried using a piece of graphite pencil lead and it did not work. Does anyone know if a zero ohm resistor would work? Are there any Fordbarners with an electronics background who could devise a solution? Last edited by 19Fordy; 09-26-2017 at 03:53 PM. |
09-26-2017, 05:18 PM | #42 |
KS has a different type of resistance unit on the older fuel quantity senders than they did on the later ones. The later ones had a small resistance spool but the early ones have it set up like a fuse holder so they could change them easily. They must have had quite a few different ones to pop in those things when they adjusted them at the factory. They likely color coded them or something but I just don't know. A person has to have some way to adjust it like a trim pot but I have no idea what the values (high and low) of the pot would have to be to make one work properly.
09-26-2017, 05:23 PM | #43 | |
09-27-2017, 07:26 AM | #44 |
The power and current values associated with the sender units are too high to to use a small variable resistor to calibrate the unit. Power dissipation can be as high as 1.2 W and .3A respectively at "full tank". Similarly a carbon resistor will likely be too big as well.
