08-16-2017, 11:54 AM | #1 |
31 town sedan tool box
can anyone provide information about the 31 town sedans that have a tool compartment under the front seat that extends down such that it requires a Mitchell overdrive that has a shortened rear tube and stub shaft to allow clearance for the tool box.
Tom Endy |
08-16-2017, 12:03 PM | #2 |
Re: 31 town sedan tool box
Tom, in all my years of removing parts from Model As, I have never came across a sedan that had as a factory installed item, a tool box under the front seat. I have found a couple cars that had an after market box installed under the rear floor, but never under the front seat.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
08-16-2017, 12:16 PM | #3 |
In all the years I have been rebuilding rear axle assemblies and installing Mitchell overdrives I have been aware that the Victoria, A-400, and the 31 two door phaeton have a dropped floor pan under the back seat. This requires a Modified Mitchell overdrive. It has the gear box positioned four and a half inches further forward and the top rear of the housing is machined down somewhat in order to clear the pan.
I recently did a job for a customer who has a 31 town sedan that he says has a factory tool box under the front seat. The overdrive he received from Mitchell has a longer front tube and a shortened back tube with a corresponding shorter stub shaft. On the data plate of the Mitchell housing the words "tool box" are stamped. I have not seen the car, only the rear axle assembly and the overdrive. The owner doesn't know if his car is a Briggs or a Murray, or Ford. He said that when he ordered the overdrive Sue Mitchell asked him if the car had the tool box under the front seat. This is new to me, that is why I am asking the question. Tom Endy |
08-16-2017, 05:35 PM | #4 |
When I fitted the Mitchell O/D to my 1929 Phaeton, it was was going to hit the under floor storage compartment put there by Ford for the side curtains. I was unaware of a special setup by Mitchell that might have overcome this. Maybe they didn't know about it themselves back then. Anyway, I modified the compartment and made a decent sized one for tools etc which saddles the torque tube just in front of the O/D unit. Access is through the floor in the back.
08-16-2017, 09:31 PM | #5 |
I have never seen a factory tool box under the seat. There is a depression under the front seat. I think if you take measurements, you will that like the Victoria, the rear seat floor pan is the culprit.
Brian SATX |
08-17-2017, 05:45 AM | #6 |
