Old 01-27-2017, 11:57 AM   #1
sphooch
sphooch's Avatar
Cool sparton horn help
Hi guys , I have a problem with the horn, need some help . Using Les Andrews book as a guide, I've rewound the field coils, 48 turns ea. one cw. and one cc. I installed new brushes, new insulating washers , soldered all the connections , oiled the pads, greesed the wheel, but the horn doesn't work. I'm using a battery charger with the high and start switch in the start position. even hooked up to the batt. I get the same results . THE MOTOR SPINS FREELY when the adjusting screw is backed all the way out ,as I turn the screw in to get the sound , the motor is slowing down.???I searched this site which had all good info. but nothing relating to this problem. before the rebuild the horn worked better, just not the right sound and now its worse. Can any one shed some light on this??? thanks THE HOOCH
sphooch is offline   Reply With Quote
Old 01-27-2017, 12:09 PM   #2
JohnLaVoy
JohnLaVoy's Avatar
Default Re: sparton horn help
Try it on a battery rather than the charger.
JohnLaVoy is offline   Reply With Quote
Old 01-27-2017, 12:27 PM   #3
Jacksonlll
Jacksonlll's Avatar
Sounds like a lot of horns out there. They will only work when you rev the engine and give it a little higher voltage. The motor is just not powerful enough the way it is. Your variables are the brushes and the windings. If everything is clean with no internal shorts, then it must be something in the windings. A touchy area. Find someone who knows a lot about windings. They should be able to help, or maybe someone on the Barn knows this area. Good luck.
Old 01-27-2017, 12:34 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Is the wedge (chisel point) on the diaphram clocked correctly to the wavy washer?
The line of the chisel point needs to line up with the line of the wavy washer groove.
It only takes a light contact of these two parts to make the right sound.
Old 01-27-2017, 12:54 PM   #5
René W
René W's Avatar
I had the same problem,i solderd thicker wires to _and+ and the problem was gone.
A former owner had replaced the wires for modern wires used in 12 volts,6 volts needs thicker wires.
It is a pile of shit bit it's my pile of shit
René W is offline   Reply With Quote
Old 01-27-2017, 06:51 PM   #6
nstegall
THE HOOCH,
Provide me with your phone contact and I will call and discuss the art of rewinding and restoring these wonderful horns or you may phone me.
Regards,
Neil Stegall
THE HORN MAN
601-469-0878
nstegall is offline   Reply With Quote
Old 01-28-2017, 09:16 AM   #7
sphooch
sphooch's Avatar
Hello Neil, I just read your message, its Sat. the 28th @8:30 am . Thank you so much I'll give you a call today. Today is my special day I'm back from Viet Nam 48years so its all good. THE HOOCH [ Steve ]
Old 01-28-2017, 11:12 PM   #8
Herb Concord Ca
If you haven't done this yet, with the horn motor running not contacting the ratchet wheel, use some fine sandpaper to polish the commutator. then clean the slots between the commutator segments.
Herb Concord Ca is offline   Reply With Quote
