Old 11-17-2023, 04:00 PM   #1
edwardbarras
Default 49 Ford Flathead v 8
Tring to start the flathead, no spark. Where should I start?
edwardbarras is offline   Reply With Quote
Old 11-17-2023, 06:44 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 49 Ford Flathead v 8
Check the point gap. Then the condensor.
Old 11-17-2023, 06:51 PM   #3
tubman
tubman's Avatar
Then the coil.
Old 11-17-2023, 07:04 PM   #4
Ggmac
Make sure you have voltage going to the coil .
Ggmac is offline   Reply With Quote
Old 11-17-2023, 10:10 PM   #5
cas3
Been sitting a long time? maybe just clean the points.
Old 11-17-2023, 10:27 PM   #6
alanwoodieman
even brand new points must be polished to make them work, used to buy napa brand points/condensor and have no trouble but lately i have had to polish new points from to get them to work--
alanwoodieman is offline   Reply With Quote
Old 11-18-2023, 12:02 AM   #7
mobileparts
I have the best set of points and condensers ever invented —- the old Standard BLUE STREAK, and U.S.A. Made Caps and Rotors, if you would like….
Always best to simply call me —- 516 - 485 - 193five…. Craig….
mobileparts is offline   Reply With Quote
