Old 09-01-2014, 11:03 AM   #1
Rocketsled
Rocketsled's Avatar
Default Argentine A
I'm working on a Argentine built '29 Roadster. Is there a RHD
wiring diagram that someone could post?
Thanks,
Rocketsled
Rocketsled is offline   Reply With Quote
Old 09-01-2014, 01:04 PM   #2
john charlton
john charlton's Avatar
Default Re: Argentine A
It is no problem to use the LHD harness . The loom to the head lights and tail lights work just fine as it is easy to "rotate" them to suit. All you have to do is extend the horn wire and the wire to the generator . I make sure I have a good watertight connection and use small cable ties to secure the extended wires to the left hand head lamp loom which runs across under the radiator . If your clips are intact to hold the loom on the rad bottom they work just fine.
John in light rain sunny tommorrow Suffolk County England .
Old 09-01-2014, 01:06 PM   #3
john charlton
PS Just use the LHD wiring diagram .
John in same weather Suffolk County England.
Old 09-01-2014, 02:13 PM   #4
john charlton
OOPS for wire read wires.
John still in Suffolk County England.
