12-03-2015, 01:33 PM | #1 |
Front spring removal
I have noticed a sag in my truck. The front spring needs to come out and I would like to know if I can do this without removal of the front axle and wishbones. Will I be able to block up the frame, remove the shackles, drop the axle and unbolt the spring from the frame?
12-03-2015, 02:01 PM | #2 |
Re: Front spring removal
You don't state the year, but yes, you can block up the frame and remove the spring. Depending on the year you may need a spring spreader to release the tension in the spring before removing the shackles.
12-03-2015, 02:07 PM | #3 |
1940, thanks, I didn't want to have to remove the hyd. hoses.
12-03-2015, 02:27 PM | #4 |
A 40 will require a spring spreader, but you do not need to remove the brake hoses (assuming there is enough slack in the hoses). Need to unbolt the spring at the center of the front cross member and remove the U-bolts. The spring spreader will relive the pressure in the spring so that the shackles can be removed. The shackles may be very difficult to get out depending on their condition. Be careful with the spring, it has a lot of power stored in it when under tension. If you need to take the spring apart there have been several threads on that topic.
http://www.jalopyjournal.com/forum/t...pickup.619439/ http://www.jalopyjournal.com/forum/t...g-tool.646689/ https://fordbarn.com/forum/showthread...pring+spreader Last edited by JSeery; 12-03-2015 at 02:47 PM. |
12-03-2015, 02:35 PM | #5 | |
12-03-2015, 02:40 PM | #6 |
12-03-2015, 02:46 PM | #7 |
Jon C. Rent a Port-A-Power to spread the spring unless you want to build one. The thread below describes in detail how I removed the original spring and installed the Posie reversed eye spring. I removed the spring without a spring spreader (the first time) but did make a spreader later on when I found the materials. I was surprised that there was not very much pressure required to spread the spring. It's a good read.http://www.fordbarn.com/forum/showth...e+front+spring
12-03-2015, 03:54 PM | #8 |
I'm about to pull the spring on the front of my '40 Tudor to reverse the eyes (or install a new Posie's spring). When spreading the spring, is it just a matter of going until you can feel the shackles are loose, or how do you know when you have it spread far enough?
12-03-2015, 06:59 PM | #9 |
Yes, you can feel when the shackles are loose enough to "wiggle'. Be sure to read my earlier post #7.
12-03-2015, 08:52 PM | #10 |
Thanks, that makes sense. I appreciate the advice.
Sent from my iPad using Tapatalk |
12-04-2015, 11:33 AM | #11 | |
12-04-2015, 12:12 PM | #12 |
Now that is a very good idea. THANKS.
12-04-2015, 02:26 PM | #13 |
Same procedures apply to front spring on a '46 Merc? Thanks.
Butch |
12-04-2015, 04:34 PM | #14 |
Thanks every one I got the spring out today without damage. Monday it's off to the spring shop in Binghamton to get renewed. I want to keep the original style of tapered leaves so i am bringing a spring from a 46 (front) I hope they can use some of each to build me a good one.
12-04-2015, 06:18 PM | #15 |
I hadn't thought about spreading it with the eyes reversed, but that sure looks like an easy solution for how to do it. I just need to decide whether to reverse the eyes on the original old wrapped springs or spend the $179 for the Posies spring. I'm wondering how much lower the new spring would be than the 75 year old one that's in there now.
