05-22-2022, 11:51 AM | #1 |
The quaile has spread its wings... and now they are bent...
Just came back from a longer trip with our Margarethe. Within the first 400 yards, our quaile went for a little flight. We stopped and found it, but it will not fit into the two little slots on the radiator cap anymore. The wings are about 4mm, a bit more than an 8th of an inch, too close together.
What's the best way to bend the wings apart, do i have to warm them up or will the material be generous enough to give me those 4mm back? |
05-22-2022, 09:43 PM | #2 |
Re: The quaile has spread its wings... and now they are bent...
I think heating is too likely to damage the chrome plating so doing ity cold might be your best bet. I think you should be able to get 4mm back, it's not very much but there is only one way to find out.
05-23-2022, 03:13 AM | #3 | |
I am afraid you are right. I will heat it up to about 160°C, that should help it a bit and not damage the chrome. |
05-23-2022, 04:51 AM | #4 |
Most have of those are white metal castings.
Likely a lost cause |
05-23-2022, 09:55 AM | #5 |
Heat the Quail in boiling water to protect the chrome. Good luck.
Bob Bidonde |
05-23-2022, 01:35 PM | #6 |
