06-06-2017, 05:38 PM | #21 | |
Re: The Noise From Hell! Gone But Not Forgotten.
Gives me something to do besides cut grass in the summer.
A man should do what he thinks best! "The Duke" |
06-06-2017, 07:33 PM | #22 |
If you replace all the seats (recommended), you should machine the block to a larger OD seat size. BUT - many of the valve parts houses supply new seats with a thicker/taller height than stock. Some machine shops make the mistake of re-machining the seat pockets DEEPER as well as wider (to account for the thickness of the new seats). They should NOT do this!
The right way is to only go as deep as the original seats and then use a carbide cutter to cut the height down to the correct height/depth (from above). Once the height is correct, then additional cutters are used to cut the new 3 or 5 angle valve seat. My machine shop does all of this in a milling machine - with a special 'main bearing support saddle' that is used to align the block and insure that all valves and both sides are consistent. Also, the valve angle (which also means seat angle) is DIFFERENT on one side to the next - this is how Ford designed the engine. The valve angles are different for early versus later 24 stud engines. If you need any info, just ping me. |
06-06-2017, 09:08 PM | #23 |
Thanks for the info!
06-07-2017, 07:33 AM | #24 |
Carefully inspect for cracks from the seat cut out to the bore. Lots of seats come loose because of these cracks.
Martin. |
