05-12-2010, 11:04 PM | #1 |
PCV kits
Hi guys, Does anyone know of any company that makes polution control valve(PCV) kits for my 8BA engine? Thanks in advance. Stan
05-13-2010, 01:20 AM | #2 |
Re: PCV kits
use Dorman #493-212 grommit in the road draft tube hole, its a bit loose but with some sealer its good to go, and get a pcv valve for a 3.8 liter buick, run line to manifold vaccuum and call it done.
05-13-2010, 11:11 PM | #3 |
Re: PCV kits
Thank You. It sounds so easy. Stan
05-14-2010, 12:21 AM | #4 |
Re: PCV kits
I bought a couple off ebay that are a machined piece of aluminum with the pcv valve glued into it and o-ring on the outside, fits tightly into the road draft tube hole. Includes a tee and length of rubber hose. Don't have the sellers name but might be able to go digging for it.
05-14-2010, 05:52 AM | #5 |
Re: PCV kits
I saw that add on ebay went looking and searching can't find it , Zeke
05-14-2010, 06:25 AM | #6 |
Re: PCV kits
Ken
https://www.nirgv8.org |
05-14-2010, 06:52 AM | #7 |
Re: PCV kits
I bought one of the PCV valve kits on offered on Ebay on 10/8/09. The seller was Ross Gunning who sells under the name of "gunn12". His e-mail address is [email protected]. The price was $28.50 + $6.95 shipping. It's a nice kit - IMHO - and I would buy another if the need arises.
Good luck with your project. Hope this helps. |
05-15-2010, 12:23 AM | #8 |
Re: PCV kits
Hello Ross Gunning here(gunn12). I have just become a member to the Ford barn. I sell PCV valve kits for the 49-53 Ford/Mercury flatheads. I have just put a listing on E-bay for them ( E-bay item #330433810380)
Please feel free to take a look. I do sell direct should you miss the auction. Just a pat on the back here...To date I have sold over two hundred fifty of these with no complaints. Thank you for your interest, Ross Last edited by gunn12; 05-21-2010 at 12:37 AM. |
05-15-2010, 12:33 AM | #9 |
Re: PCV kits
No offense Dude, but my way is less than 15 bucks.
Grommit is 6 bucks with tax, valve is 3 bucks with tax, hose is a couple bucks. |
05-15-2010, 04:46 PM | #10 |
Re: PCV kits
I came up with a little different PCV setup for my Merc. I am going to run an electric fuel pump, so I used an early fuel pump stand and modified it for a PCV valve under it. This also lets me use a molded hose and hide it in the rear of the engine.
05-19-2010, 08:58 AM | #11 |
Re: PCV kits
05-19-2010, 12:10 PM | #12 |
Re: PCV kits
I ran a electric fuel pump on my 36 took the road draft tube off and running a offy intake made a plate out of aluminum polished it and fitted a grommet and buick pvc all for less than 5 bucks. Chris
05-19-2010, 12:27 PM | #13 |
Re: PCV kits
I took out the oil fill and the road draft tubes to put a Merc manifold on a 59ab... Freeze plugs fit these two holes, upside down, drilled one and put a pcv valve (1/4" pipe) from a 250 c.i. engine in line with a Rochester 2cv Carb... Works well... Karl
05-19-2010, 01:35 PM | #14 |
Re: PCV kits
That's a neat way to do it. Question; how did you plug the blow by (road draft tube) hole in the front of the intake?
05-19-2010, 01:58 PM | #15 |
Re: PCV kits
Great info, will try it .Bob
05-19-2010, 02:11 PM | #16 |
Re: PCV kits
Bob/Ohio,
In addition to Vic's question, where does the air enter, and how does it flow through the engine? |
05-19-2010, 05:16 PM | #17 |
Re: PCV kits
V8 Bob,I still have the stock breather tube in the front of the intake to draw in fresh air. Vic, I left the stock road draft tube on for looks, but I turned out plastic plug and drove it in the lower end of the draft tube, and painted it black.
Bob |
05-19-2010, 05:30 PM | #18 |
Re: PCV kits
Ross Gunning
I looked on eBay under item 3304338103800 and it said it wasn't there??? Dave(Smith) |
05-19-2010, 06:36 PM | #19 |
Re: PCV kits
That's a neat idea, I might try that on our '53 F-100 Panel Truck.
05-19-2010, 06:55 PM | #20 |
Re: PCV kits
Just another way of doing the same old thing! I just wanted to hide things in the back of the engine, and not have a long hose on top of the engine.
