Old 05-24-2021, 10:03 PM   #1
russdianajones
Default 1923 Model T Replacement Gas Tank
Does anyone know where I can find a fuel tank for a 1923 Model T? The weld at the bottom of the fuel tank where the brass fitting seats had cracked. I’ve tried fixing the crack but it keeps springing leaks. I think it’s time to start searching for a replacement.
russdianajones is offline   Reply With Quote
Old 05-25-2021, 12:32 AM   #2
redmodelt
redmodelt's Avatar
Default Re: 1923 Model T Replacement Gas Tank
Fix the one you have. Place and ad here, MTFCA, Facebook pages or parts wanted on AACA. Unless someone has one sitting, dealers are out of stock because the guy making them died. It is not a weld it is soldered.
Old 05-25-2021, 10:32 AM   #3
stevests
stevests's Avatar
Take it to a reputable radiator repair shop !
stevests is offline   Reply With Quote
Old 05-30-2021, 02:05 PM   #4
Kajtek1
Kajtek1's Avatar
Brazing should fix it good.
Radiator shops usually do solder, so check if they have person good in brazing.
Kajtek1 is offline   Reply With Quote
Old 05-31-2021, 09:46 AM   #5
stevests
stevests's Avatar
Originally, they were soldered not brazed. Considering the thickness of the tank steel being so much thinner than the cast brass sediment bulb flange, the heat generated by brazing would most likely burn through the tank steel - have it soldered professionally.
Old 05-31-2021, 09:52 AM   #6
Will N
Will N's Avatar
Snyders sells repro tanks:
https://snydersantiqueauto.com/Produ...del-t/gas-tank
Will N is offline   Reply With Quote
Old 06-03-2021, 11:38 AM   #7
redmodelt
redmodelt's Avatar
Flames and gas tanks don't come to good ends, except maybe getting your wings or horns! "BOOM"
Old 06-07-2021, 04:53 PM   #8
tinman7
tinman7's Avatar
Nice looking T. Where did you get the PU bed?
tinman7 is offline   Reply With Quote
Old 06-07-2021, 06:21 PM   #9
J Franklin
J Franklin's Avatar
A bed like the one in the photo can be purchased from the good supply houses. I see his was hand built.
Old 06-11-2021, 07:32 PM   #10
russdianajones
My dad handcrafted the PU bed, he loved that Ford.
Old 06-14-2021, 08:03 PM   #11
Rodrelic
Can get some, round or oval?
Rodrelic is offline   Reply With Quote
