Old 05-16-2021, 06:36 PM   #1
Football1
Default Remove oil pan 1940 ford coupe
Can someone walk me through removeing oil pan and oilpump from my 1940 ford coupe
thanks football1
Football1 is offline   Reply With Quote
Old 05-16-2021, 08:33 PM   #2
Kube
Kube's Avatar
Default Re: Remove oil pan 1940 ford coupe
Um yeah, I can.
In my opinion, it is much easier and quicker in the long run to remove the engine in order to remove the pan.
If that's not in your future:
Remove the floor boards and transmission cover.
Remove the starter.
Remove the bolts that hold the transmission to the pan. Leave the others installed.
Remove the chatter rods from the frame and engine. Do not leave them in the block!
Remove the transmission mounts.
Remove the engine mounts at the water pumps.
Remove the drag link and tie rod.
Remove the dip stick and tube.
Remove the fuel pump and fuel pump stand.
Jack up the front of the engine as far as possible. Place blocks between the foot of each water pump and the front cross member.
Remove all of the bolts that are currently holding the pan to the block. Break the seal of the gasket.
Now it's time to lower the pan. You may very well have to turn the engine until the crankshaft (front) throw is at it's high point. This allows a bit more clearance to remove the pan.
Once the pan is off, removing the oil pump is a straight forward task. Only one bolt holds it to the block. The head of the bolt was originally safety wired.
I find it best to remove the engine (and quicker) for a couple of reasons. The biggest reason? Installing the pan from below and getting the gaskets in proper position is a pain in the butt. Plus, if you don't get the rear seal in correctly, well, you won't know until you drive the car. Do you really want to risk doing this task twice?
Now, may I ask why you want to remove the pan and pump?
Old 05-16-2021, 10:16 PM   #3
19Fordy
19Fordy's Avatar
Wow! Mr. "Kube" sure gave a complete explanation. Well done.
Take his advice and remove the entire engine. You'll be glad you did. It will save you tons of work and aggravation.
Old 05-16-2021, 11:22 PM   #4
Ken/Alabama
Ken/Alabama's Avatar
I done it years ago by placing Jack stands under the frame and removing the front axle and wishbone and exhaust cross over pipe. But then you’ll be laying on your back trying to get the gaskets in place. Either way it’s a pita.
Ken/Alabama is offline   Reply With Quote
Old 05-17-2021, 07:41 AM   #5
big job
big job's Avatar
Kube is right; way faster to remove engine whats to loose a rainy weekend? Then you can clean things up give it a paint job and drive off Sunday :
big job is offline   Reply With Quote
Old 05-17-2021, 07:41 AM   #6
miniceptor86
miniceptor86's Avatar
I did this a month ago. I thought about it a lot (ok, procrastinated). I decided to pull the engine. I decided I would have the best chance of Getting everything back together properly to have the pan not leak which was my goal.
Cheers,
Jim&Sandy
McGregor, IA
miniceptor86 is offline   Reply With Quote
Old 05-17-2021, 08:54 AM   #7
rockfla
rockfla's Avatar
Is having a lift make it any easier AND not having to lay on your back??? OR is having a Mercury with a few extra inches of "length"?
