Old 06-12-2021, 01:33 PM   #1
2935ford
2935ford's Avatar
Default Piston Placement
30 over pistons. Pulled them for a small rebuild.....removed babbitt and now full insert motor.
My question.....which way do these go back in? Forgot to take note when removing.
2935ford is offline   Reply With Quote
Old 06-12-2021, 02:53 PM   #2
MAG
MAG's Avatar
Default Re: Piston Placement
The splits go to driver (left) side.
Are the rods installed on the pistons with the rod dippers in correct direction? To pick up oil when the engine rotates?
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 06-12-2021, 03:04 PM   #3
2935ford
2935ford's Avatar
MAG thanks.
From the front facing the vehicle the the rotation is clockwise so the rods will have the dippers facing to the left for picking up oil is what I understand.
Old 06-12-2021, 03:31 PM   #4
Russ/40
Russ/40's Avatar
2935ford, are those pistons knurled ?
Old 06-12-2021, 06:53 PM   #5
2935ford
2935ford's Avatar
Russ/40 I honestly do't know.
They have some kind of pattern to them. Don't know what was done.
30 over with non adjustable lifters?
Who knows why or what some people do?
Other than the rear main leak due to a poor babbitt job......the engine ran smooth, quiet and with pretty good power.
Old 06-12-2021, 07:20 PM   #6
Synchro909
Synchro909's Avatar
Originally Posted by 2935ford View Post
MAG thanks.
All this talk of facing the left, facing the driver's side etc all leave room for confusion. For example, if something is to be facing the driver's side, it is completely wrong wrong in RHD world. I prefer to say the dippers face the camshaft. No confusion, even when the engine is upside down.
Old 06-12-2021, 07:30 PM   #7
2935ford
2935ford's Avatar
I don't care as long as it is correct!
Old 06-12-2021, 10:54 PM   #8
Synchro909
Synchro909's Avatar
My comments weren't aimed at you, 2935. They were intended as a general observation and suggestion. You are on the money, so long as it correct, what matters?
Old 06-13-2021, 01:09 AM   #9
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
What’s your piston clearance?
Old 06-13-2021, 08:57 AM   #10
2935ford
2935ford's Avatar
Synchro909.....never took it that way.
I just want to do it right before I assemble it and find out it's wrong!
Chuck Sea/Tac.......I will have to check that. Before the tear down as I mentioned it ran very well. No unusual noises and had lots of power. I tore it down to fix that rear main leak and decided to go inserts.
You always find something on something you didn't build yourself.
This A is just a fun car to putt around in and with. As I drive it and work on it, I fix what I find and keep driving. They are such fun cars to own.
