Old 06-10-2021, 07:46 AM   #1
rockfla
rockfla's Avatar
Default Vintique 32-36 Open car wiper arm kit
Anyone here on the barn "maybe" have a Vintique 32-36 Open car windshield wiper kit sitting around you would like "Possibly" liquidate OR preferably "leftovers" from maybe only using one of the two wiper arms and shaft??? I need one part out of the whole kit and whomever Vintique is having make them for them has changed and doesn't make the one part with the kit anymore and I ordered a whole new kit to get this one part and its not with it SO it would possibly have to be a kit from a few years back or more!!!!! Before I have my machinist make it I figured I'd give the "Barn" a last ditch chance.
Thanks
Rockfla
Old 06-10-2021, 05:10 PM   #2
Bursonaw
Bursonaw's Avatar
Default Re: Vintique 32-36 Open car wiper arm kit
Thanks
Rockfla
I might be helpful to post a picture of what your looking for?
What part of the kit are you looking for?
Regards
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 06-11-2021, 06:20 AM   #3
rockfla
rockfla's Avatar
Ask and you shall receive, here is the washer I am seeking.
Old 06-11-2021, 09:21 AM   #4
deuce lover
deuce lover's Avatar
OD and hole dia Robert?
Old 06-11-2021, 11:54 AM   #5
woodiewagon46
If it's only the washer and rubber you are looking for, what you are picturing looks very much like Model A Ford windshield swing arm washers. Look at www.Brattons.com part number30140.
woodiewagon46 is offline   Reply With Quote
Old 06-11-2021, 12:02 PM   #6
woodiewagon46
Ford used a lot of parts from other years on different models. For example, the part that I recommended for you, is also used on my '46 Woodie, as the lift gate lock anchor. One is used on each side under the swing arm nut, also same as Model A, to hold up the lift gate.
Old 06-11-2021, 12:12 PM   #7
rockfla
rockfla's Avatar
Thanks, will give it a look see!!!
Old 06-11-2021, 01:12 PM   #8
DavidG
DavidG's Avatar
While they look the same, it's not the same washer (o.d. too big and i.d. too small).
Old 06-11-2021, 03:49 PM   #9
woodiewagon46
But it may work for his needs David.
Old 06-11-2021, 05:40 PM   #10
DavidG
DavidG's Avatar
Robert is one of those who prefer sticking to the originals wherever possible.
Old 06-12-2021, 05:27 AM   #11
Ray Balukas
Ray Balukas's Avatar
Rockfla, I may have what your looking for. is the washer 7/8" measuring from the open side. with 1/2" hole
Ray Balukas is offline   Reply With Quote
Old 06-12-2021, 09:38 AM   #12
DavidG
DavidG's Avatar
The original was 3/4" o.d. and the hole size was 21/64".
Old 06-12-2021, 11:27 AM   #13
David J
David J's Avatar
I have the factory WS frame off Mikes 34 phaeton that has the stud assy for a second wiper . Old stuff but the washer you seek is taller than the repop in your pic . Send a pm with a phone number and I will text pics . Posting pics here is not working for me anymore .
David J is offline   Reply With Quote
Old 06-12-2021, 03:13 PM   #14
rockfla
rockfla's Avatar
The ID by my trusty Mititoyo’s
ID. .345. So 23/64ths is just over
OD. .80 so 13/16thz would work
OR as amazing DavidG posted, that too!!
Old 06-12-2021, 04:33 PM   #15
woodiewagon46
I just measured one on my '46 Station Wagon, lift gate lock. The O.D. is .814 and the bore, or middle hole is .320, a tad over 3/16".
