06-08-2021, 02:46 AM | #1 |
1933/34 fuel gauge air line routing thru firewall.
Just want to verify that the fuel gauge airline goes thru the same hole in the firewall on a 33/34 as the wiring harness, temp sender etc?
The logical place appears to be with the speedo cable but this may not be correct. Thanks Graham |
06-08-2021, 03:14 AM | #2 |
Re: 1933/34 fuel gauge air line routing thru firewall.
Originally, the '33-'34 V8 fuel gauge air line was routed through the same hole in the firewall as the main wiring harness.
06-08-2021, 04:46 AM | #3 |
