10-13-2012, 05:11 PM | #1 |
Toe-in Adj. tool
It became very aparent to me today that my toe in needed better adjustment. After a day of enjoying the changing of the leaves on the back country roads in Westen PA I totaly shreaded a good tire. When I put the front end together I attempted to check the toe-in with a wodden ruler. Thought It was close, I was wrong. Any one have instructions on how to build a more accurate tool to measure the toe in? Or If on could be purchashed? I did a search and found nothing on the subject. thanks |
10-13-2012, 05:32 PM | #2 |
Re: Toe-in Adj. tool
Here are three photos of an alignment tool I built based on a design one of our club members came up with. Works great!!! I use masking tape on the tire and the edge of the tool. The ends of the alignment tool where it comes in contact with the tire are beveled so you get good contact with the tape on the tire. This is where I make my mesurement with a small scale.
hope this helps Last edited by 160B; 10-13-2012 at 07:04 PM. |
10-13-2012, 05:55 PM | #3 |
10-13-2012, 07:02 PM | #4 |
The tool is called a "Duby Wheel Alignment Gauge." A Google search will get you several suppliers. Still made exactly like the the one in the Ford Service Bulletins. Price $70. to $100. depending on the supplier.
10-13-2012, 07:35 PM | #5 |
I have used the Duby gauge and it worked great. Don't smoke a duby before using the Duby or everything gets messed up.
10-13-2012, 07:48 PM | #6 |
01-17-2024, 11:15 AM | #7 |
I used a 1" round spring loaded curtain/shower rod and it works just great. Kinda like yor flat rod.
10-13-2012, 08:11 PM | #8 |
Toe at 1/16 +- 1/32, Close enough.
10-13-2012, 08:21 PM | #9 |
Recently, I asked some question about 1932 Ford front end specifications and got a lot of great answers. The local Ford garage dialed my front in at 1/2 degree - laser methodology. Tires are now wearing even and we track much better in a cross wind. Mine had too much tow out, with similar disatrous tread wear.
01-14-2024, 11:14 AM | #10 | |
Local Ford garage that does Model A's or any car? TIA |
10-13-2012, 09:17 PM | #11 |
1/2 degree of what??
Paul in CT |
10-13-2012, 09:34 PM | #12 | |
http://www.abarnyard.com/ |
10-13-2012, 10:32 PM | #13 | |
www.whidbeymodelaclub.com |
10-15-2012, 09:13 AM | #14 |
10-15-2012, 10:52 AM | #15 |
As Gary posted, NAPA Part no. 807-2000 Alignment Gage.
10-14-2012, 10:07 AM | #16 |
Someone recently posted that he pushes 2 straight pins into tire tread, measures between them, rolls car forward, and measures again! NOT BAD!
I think I read somewhere that the measuring point should be 11" above the floor. Saw a pic of some brand name, spring loaded toe in guage that goes between the tires, and it had 2 skinny 11" chains dangling, that guaged the proper height. Bill W.
10-14-2012, 10:54 AM | #17 | |
http://abarnyard.com/workshop/align.htm |
10-14-2012, 11:21 AM | #18 | |
Thanks for the correction I just told the Dog to help me remember that! LOVE THAT DOG! Bill W.
10-14-2012, 12:53 PM | #19 | |
10-14-2012, 07:59 PM | #20 |
Marco,
I read your posting and found it very helpful when I adjusted toe-in. Marc |
