06-03-2021, 11:41 AM | #1 |
Identiy type of machine screw 46 woodie door handle
Ok, on the front doors of the woodies 46-48 there is a small hole on the INSIIDE of door that is inline with the outside door handle shaft. A small machine screw 10-32 with a long slotted head inserts into hole and screws ihto back of door handle shaft. What are these fasteners called so I can find one and buy it? Person that replated my parts lost one,I need another. thanks!
06-03-2021, 11:48 AM | #2 |
Re: Identiy type of machine screw 46 woodie door handle
Not sure but would most likely guess this is the type screw and IF so it is an Oval Head Slotted Machine Screw
06-03-2021, 11:50 AM | #3 |
Nope,thanks
06-03-2021, 11:54 AM | #4 |
Following
06-03-2021, 12:01 PM | #5 |
10/32 round head slotted machine screw along with a star lock washer. (hardware store items)
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 06-03-2021 at 02:35 PM. |
06-03-2021, 12:05 PM | #6 |
06-03-2021, 12:05 PM | #7 |
Tried taking pics and sending but no luck. The head on this type fastener is nearly as long as threaded portion. I think early 30's fords may have used this style of bolt on door handles also
06-03-2021, 12:07 PM | #8 |
No and no. Those are both very common fastners. No lock washer
06-03-2021, 12:08 PM | #9 |
Post a pic of the one you still have. It would help a lot.
We both posted at once. |
06-03-2021, 12:09 PM | #10 |
these are the other two commercially available types of head I can think of that it could possibly be IF not a Round, Flat or Oval head. IF its not one of these then its a "special" make screw!!!!
06-03-2021, 12:20 PM | #11 |
46 WOODIE. nothing like other models. BUT, I have seen these bolts before. Similar to fillister but head even longer. Yes, may have been special made forvthis and a few other models
06-03-2021, 12:21 PM | #12 |
If not round head then 'panhead'
06-03-2021, 12:24 PM | #13 |
Cheese head is the only other style and between the cheese head and Fillister head its splitting hairs!!!! IF its not a cheese or fillister your SOL. unless you find someone here on the barn that has that particular screw
06-03-2021, 12:26 PM | #14 |
Various earlier inside door handles were secured with nickel-plated #10-32 pan head screws.
06-03-2021, 01:35 PM | #15 |
What you are describing sounds like a shoulder screw. You might try McMaster-Carr.com to see if you can find a size that works for you. The only one I found without a head is only available in metric threads.
Thread size=10-32, shoulder diameter=?, shoulder length=? https://www.mcmaster.com/screws/shoulder-screws/ P.S. it looks like for a 10-32 screw the shoulder diameter will be 1/4" from McMaster-Carr. Last edited by Zeke3; 06-03-2021 at 01:43 PM. Reason: added fastener characteristics & PS |
06-03-2021, 02:00 PM | #16 |
Alright,attached a pic,may help
06-03-2021, 02:08 PM | #17 |
I have one. The head is nickel plated and7/16 dia and length is 5/8 and its brass .
If that works for you click on my user ID and send me your address.I posted this before I saw his picture.Oh well I tried. Last edited by deuce lover; 06-03-2021 at 03:21 PM. |
06-03-2021, 02:28 PM | #18 |
What you have pictured in the first post you will not find anywhere as a commercially available item. Support your local machinist!!!
06-03-2021, 02:36 PM | #19 |
Sheldon,
That's not an easily-found fastener these days as the head diameter is that normally found on a #12 screw of the same type. They were used on early '32s to attach the dash to the cowl before the hole size was enlarged from #10 to #12. |
06-03-2021, 02:44 PM | #20 |
Thanks Sheldon, knew I had seen them before.
Dont have to have new. Someone from project will come up with one. Thanks deuce lover,looks identical to mine |
