Old 09-04-2021, 11:49 PM   #21
55blacktie
Default Re: What Y-Block camshafts work well with automatic transmissions?
Who manufactures a billet flat-tappet cam for anything other than diesels?
55blacktie is offline   Reply With Quote
Old 09-05-2021, 02:30 AM   #22
JeffB2
JeffB2's Avatar
This may be a better option,a lot of guys on the H.A.M.B. use them for vintage engine camshafts instead of buying a "Cam in a box" camshaft if you give them the exact specs of your engine and it's intended use they can grind you a custom grind to fit your exact needs. https://deltacam.com/ They also can apply a hardening to better withstand today's engine oils.
JeffB2 is offline   Reply With Quote
Old 09-05-2021, 10:39 AM   #23
55blacktie
oregoncamshaft.com also good. They can regrind your cam or provide new.They know Fords. Tim McMaster (y-blockguy) uses them. They also resurface y-block lifters.
Old 09-05-2021, 03:35 PM   #24
Pete
Pete's Avatar
If you decide to go with a steel billet, have Jones Cams do it.
[email protected]
Mike Jones designs and grinds cams for many of the top teams in just about any type of racing there is. He can do a steel billet, furnish the special lifters required and furnish the special distributor drive gear required. All at a reasonable price.
Tell him I sent you and he might only raise the price 10%....LOL
Old 09-05-2021, 03:35 PM   #25
Pete
Pete's Avatar
[email protected]
Old 09-05-2021, 04:50 PM   #26
55blacktie
They have a billet cam for the Ford Y-block engine? What about Y-block lifters? Got to be a first.
Old 09-05-2021, 04:55 PM   #27
Pete
Pete's Avatar
I had them at one time. He should still have that stuff.
