04-04-2024, 04:42 PM | #1 |
New metal fuel line into 40 tank question
This may seem silly but I seem to have read that the metal fuel line should only go into the bung about 1/2”. First is that true? Second, if that’s true, how does it pick up fuel at the bottom of the tank? Thanks!
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
04-04-2024, 07:47 PM | #2 | |
Re: New metal fuel line into 40 tank question
The ferrule was soldered to the line originally. That's something I always do as it eliminates the possibility of air getting sucked by the ferrule / line.
04-04-2024, 07:57 PM | #3 |
Kube, as always thank you! So is there a tube or something inside
The tank that pulls fuel from near the bottom?
04-04-2024, 07:58 PM | #4 |
yes
04-04-2024, 08:47 PM | #5 |
Simple enough. Thank you!
04-05-2024, 12:10 AM | #6 |
