09-13-2014, 09:26 PM | #1 |
Sympathy pains for Old Henry
My 53 215" six decided to join Old Henry. Recently a nasty knock developed in the bottom end at the front of the engine. So it is time to dive in and see what is up. Getting this far was my Saturday project.
The head was pulled last week and taken to a machine shop. It showed receding seats and loose valve guides. Most likely the cause of intermittent skip/misfire I've been chasing for a while. The cylinders still look good. Crosshatch pattern is still visible and almost no ridge. Tomorrow I'll get a look at the crank.
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. |
09-13-2014, 10:09 PM | #2 |
Re: Sympathy pains for Old Henry
Did the 6'ers have hardened seats back then?
'52 F-1, EAB flathead |
09-13-2014, 10:19 PM | #3 |
Chuck, sorry to hear about this latest problem with the sedan delivery. Keep us posted on what you find wrong with the lower end.
09-14-2014, 03:15 AM | #4 |
Sorry about that & as JM said keep us posted & keep the pictures coming also.
09-14-2014, 07:17 AM | #5 |
Chuck,Ah the joys of owning old cars.Phil
09-14-2014, 07:21 AM | #6 |
Phil, That's why we have them. Always fun to be had Fixin' and Drivin'.
09-14-2014, 07:38 AM | #7 |
I took a six cyl. from a '53 Ford in the '80's and installed a head from a diesel tractor for a friend and we put it in a Ford Dexta tractor. Everything bolted right on. it ran good for about a week! Then, Phhht! Never looked to see what came apart. As far as I know, it is still sitting in a field.
09-14-2014, 12:56 PM | #8 |
Chuck, Perfect time to drop in a v8 of some kind. You know me aways gotta mess with them. Good luck with it, yell if you need anything, Chuck S.
PS: FLATHEADS FOR EVER!! |
09-14-2014, 01:28 PM | #9 |
09-14-2014, 09:04 PM | #10 | |
09-14-2014, 01:09 PM | #11 |
Chuck, I can relate... Been there, done that, several times... Just remember to HAVE FUN
Imagination is more important than knowledge. |
09-14-2014, 01:30 PM | #12 |
Chuck:
If you need a hand Let me know, as you know Grease is my friend. |
09-14-2014, 01:45 PM | #13 |
For 41ford1 - Might be apples and oranges here (Ford vs Chebbie) but back in the 80's I had a '66 Chebbie Nova w/ straight six developed a know. After spending a weekend underneath replacing all the rod bearing with no fix it turned out to be a broken tooth the timing gear causing the knocking noise.
09-14-2014, 02:30 PM | #14 |
Thanks for the sympathy.
I'm looking forward to seeing if you have a bearing problem like I have. Hope you're having fun driving.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
09-14-2014, 04:52 PM | #15 |
We always install hardened seats in rebuilds. Most old engines have had several regrinds of seats, leaving no room for another.
09-14-2014, 08:47 PM | #16 |
Tore in to it today. Plastigauged the rods and mains. Both show .002" to .0025". End play is at .008". All bearings and journal surfaces look decent. everything at the crank is at the high end of spec. I don't think any thing here is the source of the knock. Pistons are another story. They are running .010" to .022" smaller than the bores. The bores are good no scores, just what looks like normal wear. Crosshatching is still visible in the ring area. I had change the timing chain and gears in the spring of '12. They look OK. Right now I'm thinking piston slap is the source of the knock. It was the loudest when the engine was fully up to temp.
Guys, I've finally come to the conclusion that this stuff is heavy and I am no longer 16. But that aint gonna stop me!
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. Last edited by 41ford1; 09-14-2014 at 08:53 PM. |
09-14-2014, 09:03 PM | #17 |
Look at the rings and see if the butt ends are front to back. Some times off location you get piston slap. Also if this is and engine that needs over size valves stems.
I had a 200 6 in a 67 falcon put just new valves and run for years. |
09-14-2014, 09:14 PM | #18 |
Thanks for the reminder. There was virtually no lip at the top of the cylinders. The pistons pushed out real easily after cleaning the carbon at the top of the bores.. Cylinders 1, 3 and 6 had broken top compression rings. No. 1 cylinder was the one with .022 piston clearance.
09-14-2014, 09:07 PM | #19 |
Chuck,Normally piston slap quiets as the engine warms up due to the alum. Pistons expanding at a faster rate than the cast iron block.wrist pin s do the opposite. Phil
09-14-2014, 09:38 PM | #20 |
Is the bore over or the piston under in No. 1 cylinder? What does the cylinder wall finish look like in No. 1? How is the fitup of rod bushings to piston pins and pins in pistons? The bearings and journals on crankshaft do look nice in your pictures.
