Old 10-05-2012, 11:59 PM   #1
2tudors
2tudors's Avatar
Default Production number question for the 55,56 guys
I have found a 56 sedan delivery...How many were made?This one is a base model and Canadian.
Thanks Dave
2tudors is offline   Reply With Quote
Old 10-06-2012, 05:44 AM   #2
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Default Re: Production number question for the 55,56 guys
I've got a US made '56 Ford delivery ( Courier ) and trying to determine the same thing. I found one source stating 1808 made, but am not convinced.....
streetdreams is offline   Reply With Quote
Old 10-06-2012, 10:59 AM   #3
Oldmics
I just recently picked up a book entitled
"The Production Figure Book for U.S. Cars
by Jerry Heasley
It has a count for all of the styles made EXCEPT the Courier.
I"m thinking that they grouped the Courier in with all of the other 2 door body style count.
Can you post the Model # on the VIN plate.Should be a 59 or 59A.
Maybe I can be of futher help.
Oldmics
Oldmics is offline   Reply With Quote
Old 10-06-2012, 04:20 PM   #4
Daves55Sedan
Daves55Sedan's Avatar
I own a '55 Courier. They made about 13,000 Courier sedan-delivery wagons in '55 but I forgot where I found that info. It was in a website. I also remember from that site that they made around 33,000 Crown Victoria's in '55. So the Courier was much more rare than the Crown Vic's.
Daves55Sedan is offline   Reply With Quote
Old 10-06-2012, 04:23 PM   #5
2tudors
2tudors's Avatar
I will stop and look at it again,when I head back to work....it had a ontario number plate.
Old 10-06-2012, 07:59 PM   #6
stonewalker
stonewalker's Avatar
If it is Canadian then it would have been built in Oakville, Ontario. The code for a 1956 (and a 1955) Mainline Sedan Delivery either Ford or Meteor is 78A (they were all base models). Finding production numbers for the Canadian Sedan Deliverys (we rarely called them Couriers) is very difficult. I saw a production number of 742 1956 Meteor Sedan Deliverys (220 of them 6 cyl); but I cannot verify the number. Canadian Ford Sedan Deliveries would have probably have been a little bit higher than that. That having been said, the survival rate for commercial vehicles like a Sedan Delivery is very low compared to something like a convertible, so there would be very few around.
In general Sedan Deliveries are commercial vehicles and often grouped with Light Trucks for production numbers.
The Ford Body code 59 (and 79) in the 1950’s referred to wagons in general, not commercial vehicles, but there was a 59E “Courier” commercial wagon back in 1959 I believe.
BTW the Canadian Data Plate decodes differently than the US one.
If you need help with decoding the Data plate try this site:
http://www.valleycruisersnb.com/PDF/...INCodesIII.pdf
stonewalker is offline   Reply With Quote
Old 06-01-2016, 10:57 PM   #7
judge65
G`day Dave , I just found a book that I purchased years ago " Motorbooks International FORD PICKUP RED BOOK " and it has U.S 1955 Courier Production at 7754 , doesn`t break it down into sixes or eights though. Makes them just about the rarest `55 !! Production of the `56 was 8757...keep those numbers in your handy facts file.
John.
judge65 is offline   Reply With Quote
