Old 08-16-2017, 07:37 AM   #1
crockette1
Default Cracked block?
Yesterday I was trying to help a friend time a 32 Stock engine Model A. It was hitting on the front 3 cylinders only after we set timing. Ran a compression check, no compression on the cylinder that was missing. Pulled valve cover, intake valve sticking.
But that did not bother me so much. While taking the manifolds off water came out of one of the bolt holes. Second one from rear. Is that bolt hole bored into water jacket?
crockette1 is offline   Reply With Quote
Old 08-16-2017, 07:38 AM   #2
crockette1
Default Re: Cracked block?
Whoops. 31! Not 32.
Old 08-16-2017, 07:44 AM   #3
Dollar Bill
Dollar Bill's Avatar
Could be open to the water jacket. Sand casting is not an exact science.
Can you look into the hole with mirror/light?
Is there any moisture in the oil?
I would Permatex the stud and reassemble.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 08-16-2017, 12:26 PM   #4
hardtimes
hardtimes's Avatar
Originally Posted by crockette1 View Post
Whoops. 31! Not 32.
I have not had the good luck of having ALL stud holes in original condition when testing A/B blocks. In other words, it is common for someone to have 'pushed' thru bottom of stud hole into water jacket. Silicone , in a clean situation, will handle that leak.
Well, there is one blk that I have that doesn't have any defective holes..a nos Russian B
Old 08-16-2017, 12:48 PM   #5
crockette1
Very well, thanks for the advise and help.
No water in oil. So, I think seal the threads when reassembling.
