Old 03-27-2021, 02:05 PM   #1
STAN WHITE
Default 34 ford headlights,Disassembly
Proper way to disassemble headlights.on original 34 headlights any help from someone who knows. Thanks Stan
STAN WHITE is offline   Reply With Quote
Old 03-27-2021, 02:22 PM   #2
DavidG
DavidG's Avatar
Default Re: 34 ford headlights,Disassembly
Pull back the spring-loaded catch at the bottom of the rim and clear the protruding tabs. Pull the catch forward enough to clear the bottom of the reflector then lift the door and lens assembly upward to clear the tongue at the top of the housing and remove the lens/rim assembly. You'll note that the reflector is held in place with a raised tab on the housing on each side of the reflector (or should be). Squeeze the reflector slightly on the sides to clear the tabs on the sides. From there on everything is self evident.
Old 03-27-2021, 02:25 PM   #3
VeryTangled
VeryTangled's Avatar
You might want to have an extra pair of hands guarding the lens. Sometimes they stick to the rim, sometimes not. You don't want it falling.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
Last edited by VeryTangled; 03-27-2021 at 03:00 PM. Reason: I can't spell too gooder.
VeryTangled is offline   Reply With Quote
Old 03-27-2021, 02:56 PM   #4
nickthebandit
Correct advice from 2 knowledgeable people.
nickthebandit is offline   Reply With Quote
