08-31-2021, 09:26 PM | #1 |
Replacing inner cowl panel on 30-31
Hello
Does anyone know how this part was originally attached? I have new lower patches with compound curve but just realized the lowers are toast. So before I cut I'd like to have a better idea if they were riveted or spot welded before I open it up? The originals seems to have small holes along the top edge. The repros don't. Thanks! |
09-01-2021, 05:14 AM | #2 |
Re: Replacing inner cowl panel on 30-31
Both ….two rivets, each end and spot welded about 6 times
09-01-2021, 07:49 AM | #3 |
Thank you!
Jim |
09-01-2021, 10:52 AM | #4 |
09-01-2021, 12:30 PM | #5 |
They’re more fun putting in than taking out!
If you’re replacing the the old ones were likely rusted out. That doesn’t make finding the spots all that easy. I usually just air chisel and go from there |
09-01-2021, 01:02 PM | #6 |
