01-01-1970, 12:00 AM | #1 |
Guest
Posts: n/a
9 inch in a 54 sedan? What swaps in?
I am putting in a healthy engine in my 54 sled. I am afraid that the stock rear on my 54 2 door sedan will not be able to handle the abuse I plan to put to it. What year 9 inch will work to replace my current rear? <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #2 |
Guest
Posts: n/a
Re: 9 inch in a 54 sedan? What swaps in?
'57 thru '59 car and Lincoln Versallies (these have rear disc brakes). <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #3 |
Guest
Posts: n/a
Bolt pattern and wheelbase are the same? Just want to make sure to keep it as close as I can for wheel clearence. <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #4 |
Guest
Posts: n/a
These have the same bolt pattern and are within 1/2" +or- in width. I have a '57-'59 in my '54. <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #5 |
Guest
Posts: n/a
Thank you very much! <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #6 |
Guest
Posts: n/a
You can also use 66-70 mustang 9". 1/2 inch wider and need to move spring perches. Have a 69 rear in my 52 Vicky with 429 CJ. <table><tr><td><font face="arial"> |
