02-05-2016, 03:00 PM | #1 |
pushrod cheater
On the jalopy journal there is a valve timing indexer on u tube. Dose anyone no if this indexer is for sale. Jack.
02-05-2016, 07:27 PM | #2 |
Re: pushrod cheater
Yes, He is making an order. His Handle is CheatersPete from France. If you are not a Hamb member I can get you his email address so you can contact him.
02-06-2016, 06:18 AM | #3 |
Re: pushrod cheater
Contact for information ---
[email protected]
02-06-2016, 07:17 AM | #4 |
Re: pushrod cheater
What is a valve guide indexer? I would like to see one , I have dealt with cheaters pete and he is a prince of a gentleman to do business with. very Honest.
02-06-2016, 09:35 AM | #5 | |
Re: pushrod cheater
02-06-2016, 09:38 AM | #6 |
Re: pushrod cheater
/www.youtube.com/watch?v=Joq_gSXfu6I |
02-06-2016, 09:40 AM | #7 |
Re: pushrod cheater
02-06-2016, 09:44 AM | #8 |
Re: pushrod cheater
02-06-2016, 10:28 AM | #9 |
Re: pushrod cheater
What is the purpose of this tool??
02-06-2016, 11:25 AM | #10 |
Re: pushrod cheater
You use it so you can set the clearances on the valves in your flathead with only 2 rotations of the crankshaft. It's just a timesaver. To a lot of us, the name, "Pushrod Cheater" is kinda misleading, because we are used to "pushrods" as those long skinny things on overhead valve engines. When you remember that Ford referred to the actual valve lifters as "pushrods", things become a lot clearer.
You can do the same thing by setting the valve at it's highest extemsion and then rotating the crank 1 full rotation to set that valve. Since there are 16 valves, this method require 16 rotations of the crankshaft. This cuts turning time by a factor of 8, thus the term "cheater". |
03-02-2016, 10:51 AM | #11 |
Re: pushrod cheater
03-02-2016, 11:28 AM | #12 |
Re: pushrod cheater
51 Merc. Thanks for accidentally sharing Jungle Pam hardy. I remember her from back in the day. HOT !
03-02-2016, 12:49 PM | #13 |
Re: pushrod cheater
03-02-2016, 01:12 PM | #14 |
Re: pushrod cheater
Oops! Well, thank you sidevalve. I sure push a lot of wrong buttons on my computer too.
03-02-2016, 02:23 PM | #15 |
Re: pushrod cheater
How much are these here indexers?
Proud FNG We fixem cars. Heap Good! |
03-02-2016, 02:56 PM | #16 |
Re: pushrod cheater
I have a couple of old valve indexers like shown in the famous Racer Brown photo. They are for use with the crab distibuters. I actually had made a home made one to work the same. I cut a disk from some sheet metal and marked off the firing order around the rim. I attached with a sleeve and a set screw to the rotor shaft on the crab. I got the engine to TDC and firing on #1 and put a pointer to #1 cylinder on the disk. I figured if the cylinder was firing, the valves would be shut. You only turn the engine two revolutions. Worked fine.
03-02-2016, 08:29 PM | #17 |
Re: pushrod cheater
03-02-2016, 08:49 PM | #18 |
Re: pushrod cheater
I have one coming but the tracking info is in French.
