04-22-2021, 11:04 AM | #1 |
32 Tudor sedan front seat mounts.
Gentlemen.
I'm looking at the two metal crossmembers where my front seats ought to mount. On the passenger side (USA Car) there are two fairly large holes with decent strengthener plates below, which I can imagine having upstands similar to the Model A seat supports. On the drivers side there are no such holes just one smaller one at the right front corner area of the seat and a small hole in the rearward crossmember approximately near the left rear corner of the seat. (This hole has a twin on the passenger side. Can anyone shed any light on how the seats are fitted in a 2 dr sedan? I have model A seats so will have to improvise anyway, but knowing how the 32 ones were done would help. Is the driver's seat adjustable fore and aft? Thanks in advance.. Mart. |
04-22-2021, 11:09 AM | #2 |
Re: 32 Tudor sedan front seat mounts.
The drivers side was mounted by 2 brackets that fastened to the floor with corresponding brackets in the front edge of the seat which allowed the seat to hinge forward for access to the rear seat. The drivers side was mounted on tracks with an adjuster in the center which allowed the seat to slide forward and back for different drivers.
04-22-2021, 11:56 AM | #3 |
Mart,
Here are some photos of North American convertible sedan/Tudor sedan/Victoria front seat bottoms and tracks for the driver's side (adjustable) and passenger side (non-adjustable) that may be helpful. The passenger side seat only attached at two points in the front as it folded forward to provide easier entry to the rear seat area |
04-22-2021, 01:33 PM | #4 |
Mart I may be able to help you with the seat tracks from one of our 32 Ford sedan projects and a few other seat bottom items. If your interested you can send me a PM for info and pictures.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
04-26-2021, 10:12 PM | #5 |
Here"s a not so good pic of mine and the hole in the cross member that the pivot mount stud goes in.
04-27-2021, 10:34 AM | #6 |
Thanks again. Mart. |
