Old 12-30-2012, 09:12 PM   #1
JtownJoe
JtownJoe's Avatar
Default Valve lash
Checking the valve lash and on the spec's of .13 int. & .15 exh. all mine are .12 int. & .13 exh. Is that really important enough to try to correct or close enough for all practical purposes?
JtownJoe is offline   Reply With Quote
Old 12-30-2012, 09:20 PM   #2
mpalilonis
mpalilonis's Avatar
Default Re: Valve lash
That is close enough, as the metal warms up it will expand some and make up a bit of the distance. If you could get the exhaust closer it would be better, if not then it will work.
mpalilonis is offline   Reply With Quote
Old 12-31-2012, 12:22 AM   #3
dave in australia
A wider gap is of no detriment, except it is a bit noisier. But a too narrow gap, and when everything warms up, the valves will not seat properly, and this may give you problems in the future.
dave in australia is offline   Reply With Quote
Old 12-31-2012, 12:32 AM   #4
bgarrett
bgarrett's Avatar
My babbitt pourer guy gets hysterical if its not .015
bgarrett is offline   Reply With Quote
Old 12-31-2012, 08:40 AM   #5
George Miller
George Miller's Avatar
Just right is great.
To tight is bad, if you run your engine hard, or climbing some big hills. Good by exhaust valve.
To loose is better than to tight. I always adjust valves on the loose side. After a new valve job they will wear in the seat a little.
George Miller is offline   Reply With Quote
Old 12-31-2012, 08:50 AM   #6
Mitch//pa
Put it right to spec.
Old 12-31-2012, 09:12 AM   #7
JtownJoe
JtownJoe's Avatar
I guess the consensus is right on or OK, slightly on the looser side but no go at 1 or 2 thousands on the tighter side. I'll just have to buy a couple of wrenches to grind down thin enough to use together & loosen em' up. Thanx for all the input!
Old 01-02-2013, 08:24 PM   #8
western77
western77's Avatar
.13 and .12 are way to loose. Try .013 and .015 and you will be in the ballpark! JB
western77 is offline   Reply With Quote
Old 01-03-2013, 01:55 AM   #9
Russ/40
Russ/40's Avatar
You mean too tight.
I would leave the intakes alone, they are fine. Try to get the exhausts a bit looser, like the .015" spec.
Old 01-03-2013, 02:09 AM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Russ, notice the decimal and zero.
.13 vs .013
.13 would be 10 times the gap of .013
Old 01-03-2013, 03:32 AM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
.13 vs .013
Yup,
And my engine rebuilder's brass placque reads: BORE-.010 It's really .100 BORE! He must have flunked MATH! I only flunked GIRLS! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-03-2013, 08:53 AM   #12
Tom Wesenberg
It's an easy mistake, and since I knew what was meant I didn't even notice the ommision of the zero until Western 77 mentioned it in post 8.
Old 01-03-2013, 10:59 AM   #13
Patrick L.
Patrick L.'s Avatar
The intake lash seems fine. The exhaust could be a bit looser. I seem to remember something about them having exhaust valve burning issues and the lash was increased to .020-.022" on the B engines [which had a slightly different camshaft]. I guess most fellas run the exhausts at .015-.018" which seems to work fine. If I'm wrong, it'll be corrected, and, rightly so.
Old 01-03-2013, 01:25 PM   #14
Purdy Swoft
Purdy Swoft's Avatar
I run most of mine at .016 , intake and exhaust. With a little noise it'll keep its poise. Burned valves are no fun to fix.
