11-12-2020, 01:57 PM | #1 |
Steering wheel paint
What kind of primer and paint should I use on a repaired steering wheel?
11-12-2020, 03:59 PM | #2 |
Re: Steering wheel paint
Primer may not be necessary unless there is bare metal involved or you need to fill minor imperfections but any good epoxy primer would hold up. I use single stage polyurethane paint. If it looks too shiny then use it a while. The shine will decrease with use.
I'd avoid putting on too many coats. It adds up pretty quick and makes the wheel grow. |
11-12-2020, 04:22 PM | #3 |
Hi Herb,
I used a two component primer. Then came the 2-component epoxy paint that is also used in this country for trucks. The result is still good after 1 year.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
11-12-2020, 04:22 PM | #4 |
Thin coats of primer and paint. I usually use epoxy primer an Enamel with a hardener.
11-12-2020, 08:06 PM | #5 |
I had pretty good luck with Krylon rattle can "Fusion" It's designed for plastics.
11-13-2020, 09:37 AM | #6 |
11-13-2020, 11:41 AM | #7 |
I've had decent luck with acrylic lacquer . The cracks eventually come back , no matter what I use for a filler . For a good job , I've found it best to go ahead and replace the steering wheel with a new repro steering wheel .
11-13-2020, 12:08 PM | #8 |
I repaired the broken, missing and cracked parts w/bondo, sanded, wiped it down w/alcohol and sprayed it with rattle can enamel. Looks good to my old eyes.
11-14-2020, 08:54 AM | #9 |
I used bondo and it filled the cracks and gaps nicely .. After a fairly short time it became obvious that cracks had been repaired .
11-14-2020, 09:26 AM | #10 |
I had the same problem. Either the bondo shrunk or separated from the wheel. It went from very nice to very amateurish looking!
11-14-2020, 10:19 AM | #11 |
I’ve used devcon epoxy for cracks and minor voids
Then used a two part paint Actually DP 90 will work some like a glossy finish...I don’t Clean it well whatever u use |
11-14-2020, 10:52 AM | #12 |
For the Early steering wheel I used Rustoleum red primer. I tested it against the original color wheel and it seemed to match perfectly.
11-14-2020, 10:58 AM | #13 |
I use S.E.M.S rubber bumper paint, it looks good and holds up good.
11-14-2020, 06:23 PM | #14 |
Anyone use JB Weld as a crack and chip filler?
11-14-2020, 06:37 PM | #15 |
I’ve used JB
But like devcon better; either/or |
11-15-2020, 12:01 PM | #16 |
PB.7 A/B a good crack filler
11-15-2020, 06:37 PM | #17 |
It would help if you mentioned which steering wheel you have. I have repaired red '28 wheels by filling cracks with Super Glue and fine dust from another red wheel. After that, I simply sanded the wheel and polished it with brown shoe polish.
