12-10-2020, 11:07 AM | #1 |
Spark control lever detents worn
Is there a fix for worn spark and throttle control lever detents short of replacing the steering column?
Mine are worn almost smooth. |
12-10-2020, 11:23 AM | #2 |
Re: Spark control lever detents worn
What I have done is put a small length of plastic or rubber tubing over the control lever. It keeps the lever from wandering and keeps the detents from wearing further.
12-10-2020, 11:44 AM | #3 |
In previous threads, various fixes have been proposed. I recall someone suggested chiseling new detents in. Someone else suggested increasing the spring pressure on the levers so the worn detents would hold better. I like the non-destructive approach of the flexible tubing idea, but you wouldn't regain the click-click-click nature of the original detents.
12-10-2020, 12:04 PM | #4 |
With a hacksaw, just follow the grooves and cut new ones . Works great
12-10-2020, 12:27 PM | #5 |
Use a small thin three sided file and carefully file each groove on each side. Works fine
Bob from Northport Northport, Michigan |
12-10-2020, 12:36 PM | #6 |
12-11-2020, 01:54 AM | #7 |
T, A or other cars do the same thing.
I know the voices aren't real but damn they have some good ideas! |
12-10-2020, 05:05 PM | #8 |
I've filed them and it works, but, Tom W came up with the idea of using a chisel so no material is removed. I like that idea.
12-10-2020, 06:02 PM | #9 |
Good afternoon...on a few Model 'A's...where the spark lever plate has been worn smooth, we have just used a medium hammer and bent the plate up just a little bit until there is friction between the plate and the lever...maybe not good for show...but does work for go! Ernie in Arizona
12-10-2020, 07:16 PM | #10 |
I remember a post from the 80's where the owner soldered a BB to the bottom of the control lever...said it worked great, including the "click".
12-10-2020, 09:40 PM | #11 |
I have welded up the rods and filed them back to a slight point. Worked quite well... but yes, you need to remove the rods to do this fix.
12-10-2020, 09:53 PM | #12 |
When I rebuilt my steering gear I re-cut all the detents with a three corner file and welded up the worn bottom of spark and throttle rods and filed them back to a slightly V shape so they click in the notches nicely now. I also replaced the tension springs and brazed up and re-shaped worn ball ends on the levers.
12-11-2020, 09:15 AM | #13 |
A dremel and cut off wheel and a steady hand nice and clean and fast . That was the
fix on Ford tractors.... |
12-11-2020, 06:56 PM | #14 |
Thanks to all of you responders. Now I have good idea how to proceed.
