12-28-2017, 07:35 AM | #1 |
Parts cleaner
Gentlemen - happy holidays!
I’m looking to purchase a parts cleaner. I want one that stands on its own ( not table top). I see one at harbor frieght for $100. While that’s about my price range, I wanted to solicit opinions here. Anyone have this unit? Anyone suggest another’s better one online?
Thanks - 30-9 1939, 1940 |
12-28-2017, 08:44 AM | #2 |
Re: Parts cleaner
I have the Harbor Freight unit. The switch gave out early on but that was a simple fix. It's fine for my purposes ....
12-28-2017, 09:09 AM | #3 |
Re: Parts cleaner
Hey Tom:
What are you using for cleaning solution? I've switched to water-based Oil Eater. Jury is still out, but I don't think I have the ratio right just yet. Mine is a 30 gallon base and I'm thinking of ordering one of the barrel warmers from Northern Tool. |
12-28-2017, 09:13 AM | #4 |
Re: Parts cleaner
Also looking at the one from HF, biggest complaint is the pump motor, I'm still on the fence about purchase.
12-28-2017, 09:15 AM | #5 |
Re: Parts cleaner
The pump motor can be replaced fairly easily. I hear you though for it seems like they break when you need it the most.
I have a Saf-T-Clean that has lasted me 25 years and I put it used so who knows how old it really is. |
12-28-2017, 09:46 AM | #6 |
Re: Parts cleaner
rubber over it hard to turn on and off with wet hands. We bought solution from Napa that is green - it rules, smells good , excellent on hands (clean hands) . I got rid of the metal flex, replaced with rubber hose with a flow thru brush works for me perfectly. Oh put ya seat belt on for the solution; its bucks, but worth it- it lasts and lasts..... way better than back in the days / bucket of gas & dried and cracked skin oh ya.... |
12-28-2017, 10:31 AM | #7 |
Re: Parts cleaner
Hey, Since I use my unit rather infrequently, I have been using kerosene. It's not the best but I have brushes I use and I usually wear heavy duty latex gloves. I have been searching for a replacement cleaner so let me know how your stuff works out ...
12-28-2017, 11:10 AM | #8 |
Re: Parts cleaner
I use a Thumbler's tumbler for small parts. Carbs fit, BUT I use a non-homogenous mixture of small nuts, bolts nails and screws. Small bits will stick in carb apertures.
Liquid is 4 dollops of dishwashing soap. No damage to bolt threads |
12-28-2017, 11:38 AM | #9 |
Re: Parts cleaner
I use the harbor freight unit . Pump just quit but i ahve had it for a few years. We use purple power cleaner from advance auto . works good for what i do the most off.....
12-28-2017, 12:07 PM | #10 |
Re: Parts cleaner
I like oil eater, got some samples at a car show. I have not been able to find it since. Where do you purchase it?
Thanks Andy 1952 F1 |
12-28-2017, 12:32 PM | #11 | |
Re: Parts cleaner
I've read that PP isn't good on aluminum, but it sounds like you have no issues. Do you rinse after you clean them? Curious. |
12-28-2017, 12:33 PM | #12 | |
Re: Parts cleaner
Before careful! It strips the oils from your hands and it takes a few days for it replenish. USE GLOVES! |
12-28-2017, 01:43 PM | #13 |
Re: Parts cleaner
A cheaper solvent is diesel and more available than kerosene.
41 woodie https://41fordwoodie.weebly.com/ |
12-28-2017, 01:57 PM | #14 |
Re: Parts cleaner
What is the advantage of using a water based product compared with Varsol or mineral spirit? I've always liked using solvent parts washers and figured it's time to move up from a coffee can and an old paintbrush. But I'm only familiar with petroleum based solvent.
12-28-2017, 02:09 PM | #15 |
Re: Parts cleaner
I use diesel fuel also.
12-28-2017, 03:22 PM | #16 |
Re: Parts cleaner
checkout your dollar store for citrus cleaner
or sometimes purple power |
12-28-2017, 04:20 PM | #17 |
Re: Parts cleaner
Try to find a commercial quality washer. Swap meets are a good place to look. Much better quality than HF
Etc. I use low odor mineral spirits. You can get it at paint stores, Home Depot or chemical distributors. |
12-28-2017, 04:23 PM | #18 |
Re: Parts cleaner
I use deisel fuel or kerosene in a H/F unit. I’ve had it 5 yrs and still cleaning dirty stuff.... Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
12-28-2017, 06:12 PM | #19 |
Re: Parts cleaner
12-28-2017, 07:55 PM | #20 |
Re: Parts cleaner
I use mineral spirits in mine.
