09-26-2017, 11:46 PM | #21 |
Re: Swapped torque tube for open driveshaft need a solution for radius arms
For an easy way to do it without any machine work other than drilling holes, read this.
Also, remember this, ANY WELDING that has to be done on axle housings will bend them and they will have to be straightened. Go to the Hamb and type this into the search. "T5 or Richmond to torque tube". Don't ask me for any part numbers. I gave all of that info to half a dozen guys on the HAMB so I would not have to bother with it any more. |
10-08-2017, 06:36 AM | #22 |
I think at this point im going to eliminate the old radius arms and install ladder bars.
10-08-2017, 09:28 AM | #23 |
10-10-2017, 05:44 AM | #24 |
I want to leave the rear suspension original because I love the setup. Unfortunately have to eliminate the radius arms and use ladder bars. I have checked the conversion kits and I don't think they will work with my setup. I Didn't expect this to be this tricky. Merc is back in storage till next spring so plenty of time to consider options.
10-10-2017, 05:44 AM | #25 |
Thanks for everybodys help!!!
10-10-2017, 06:19 AM | #26 | |
03-02-2021, 03:05 PM | #27 |
Delete!
