09-11-2017, 07:35 AM | #1 |
Oil pressure dilema
37 engine, 46-8 spring in top relief, pump with relief also. Starts with 60 lbs pressure and drops to near nothing after about 20 min when it gets good and hot and begins to rattle. Had pan off to replace plugs in the rails that were leaking coolant but did not pull any rod caps. Going to pull the engine again and replace rod bearings. Anyone got other recommendations?
09-11-2017, 08:05 AM | #2 |
Re: Oil pressure dilema
change cam bearings, check clearances on main bearings-how many miles since overhaul? smokes? uses oil--then it needs a rebuild
09-11-2017, 08:10 AM | #3 |
No history on engine. Has good compression and runs well.
09-11-2017, 09:04 AM | #4 |
With the pan off inject oil under pressure in through
the fitting of the oil sender. I did this on a Lincoln V/12 and found the problem was the bypass spring in the oil oil pump. You may still have the problem with the spring you replaced. try a shim made of 1/8th inch pipe on the top of the spring, start with 5/16" long and adjust to get 50 lbs. If you have an oil pump with a bypass valve that can be the problem and fixed with the same type shim. You can test the oil pressure by removing the spark plugs, install a mechanical gauge and spin the engine with 12 volts. The oil pressure you see will be what you get at 45 MPH. You can do this with the engine in the car or sitting on the floor. G.M.
www.fordcollector.com |
09-11-2017, 10:08 AM | #5 |
It could also be the sending unit mine did about the same thing, I installed a mechanical gauge under the original sending unit. Getting 80# on start-up runs at 20# after warm-up, you could avoid pulling engine if it's only the sending unit. Al
09-11-2017, 10:54 AM | #6 |
09-11-2017, 11:10 AM | #7 |
These engines shouldn't rattle if they have just a little oil pressure. After you verify actual pressure you will have to find the excessive tolerances. You are right there at the mains when you replace the rod bearings so I would check them, too.
09-11-2017, 04:45 PM | #8 |
Thanks all, somewhere I have a chamber I made to put oil in under pressure, will take GM's advice and also check the mains while I am at it.
09-11-2017, 06:15 PM | #9 |
the pressure pot should have adjustable pressure, if you put pressure higher than the relief(full air hose pressure) valve you will have a lot of oil spraying -won't be able to tell where it is all coming from---the bearings should only drip, a steady stream usually is the pressure loss/excessive clearance ----start with low pressure, increase it till you get relief valve open---that way you check that pressure too
09-11-2017, 06:46 PM | #10 |
I take it that this is while driving and not on a stand?
Its not uncommon for the earlier ones to get near zero at idle when hot mines been doing it for years, but rattle NO ... So do you have a later oil pump in it?
09-11-2017, 07:26 PM | #11 |
id ck with gauge. and if low and rattling id say too much clearance some where.did this come up all at once?.i alwasys say if its quiet its got enough preasure unless your talkin race type engine.
Thread Tools | |
Display Modes | |
