06-24-2019, 12:17 AM | #21 |
Re: Just purchased and New Berg Radiator Wow
Penrite did have a good blurb on this, but they seem to have removed most of it. Too scary I guess.
https://www.penriteoil.com.au/knowle...coolants/395#/ https://www.penriteoil.com.au/knowle...hibitors/289#/ https://www.penriteoil.com.au/knowle...position/287#/ Their Classic Car Coolant can be used with water, or added to coolant to beef up the corrosion inhibitors: https://www.penriteoil.com.au/applic...-car-coolant#/ I'll let Scotty explain the basics: https://www.youtube.com/watch?v=qYX4kRaOvTM |
06-24-2019, 05:51 AM | #22 |
Wow! Now Im not sure which way to go now with my Brand new Radiator from Berg's?
The New Radiator is a great Cooler. I want to stop/inhibit the Rust!! as much as I can and if at all possible THanks to all, Hugh |
06-24-2019, 05:59 AM | #23 |
Brent,
Thanks. I guess you must have seen all the Follow-on Posts How about the rust? Thanks, Hugh |
06-24-2019, 06:14 AM | #24 |
30 Closed Cab, Great point in your last Post.
" This muddies things for me. Ethylene Glycol is the green stuff. The info uses "may" - under what conditions does this happen? If this is a problem, is it due to wearing out the additives over an extended period, does adding freshening additives to it correct these issues, etc?" Thanks, Hugh |
06-24-2019, 07:18 AM | #25 |
If you live in a cold climate then its coolant. If is running cool now (your summer) then leave it in all year round. As Scotty said, change it every few years and you'll be fine.
I'd be more concerned about the old chunks of rust detaching from the block and blocking the tubes. Get a filter like the Gano. |
06-24-2019, 10:32 AM | #26 | |
I was told that with a fresh radiator, and a completely rebuilt motor, and using antifreeze - in my case filter is not necessary and the flow reduction of a Gano may cause cooling issues. Your thoughts? |
06-24-2019, 10:53 AM | #27 | |
I've seen the Scotty video previously. It has a lot good info, but is centered a little around more modern vehicles, especially talking about galvanic/electrical info which is more of an issue with motors cooling/systems using dissimilar metals including aluminum. With stock As, not as much as a problem. I like that he stressed at the end not to mix types, and to flush (flush has to be really thorough by the way) if converting from one type to another. Otherwise really nasty things can happen, the coolant can turn to sludge, including destroying the motor. I wanted to read the penrite links but a table of contents blocks about half of what is on the page. How do I get that off the screen so I can read the info? |
06-24-2019, 05:14 PM | #28 | |
Anyone having flow problems with a Gano filter speak now... |
06-24-2019, 05:21 PM | #29 | |
Turn your phone sideways or read it on a bigger screen. |
06-24-2019, 05:44 PM | #30 |
06-24-2019, 05:47 PM | #31 |
06-24-2019, 10:11 PM | #32 |
Yes, it's an IE thing, I sent them an email to get them to lift their game.
06-24-2019, 10:59 PM | #33 |
Has anyone thought to ask the radiator builder what they recommend? Didn't see that mentioned and I would guess they have some thoughts. Out here in sunny CA we run a lot of things. I have a friend that uses an oz. or two of Dishwashing machine detergent with a good two oz of soluble oil. If that gets on the paint it doesn't take much effort to make the car look fine again, Some of the antifreezes are tough on paint, so I am told. Gano filter should be checked and flushed as needed,
06-24-2019, 11:24 PM | #34 |
06-24-2019, 11:59 PM | #35 | |
I've seen others mention and have used Dawn dishwashing soap and Arm and Hammer Washing Soda (not Baking Soda). Anyone heard anything negative about using these? |
