08-25-2023, 08:56 PM | #1 |
Spark Gap
I'm installing a 6.5:1 Head on my Burtz engine, and using Champion WY18 plugs. What is the recommended gap for my spark plugs
08-25-2023, 10:00 PM | #2 |
Re: Spark Gap
Spark plug gap for modified engines require a bit of experimentation on your part. you can start with standard gap setting and then either make it smaller or wider to see how the engine response changes. I set my 3x plugs at .025 for the best running when I changed to a 6 to 1 Brumfield head.
08-26-2023, 05:53 AM | #3 |
Re: Spark Gap
Depends on what ignition you are running
Sent from my iPhone using Tapatalk |
08-26-2023, 07:04 AM | #4 |
Re: Spark Gap
I have a 6.5 Burtz head, stock distributor but high output coil, and 0.035 gap. A smaller gap at the rotor in the distributor helps.
08-26-2023, 10:13 AM | #5 |
Re: Spark Gap
A big part of this hobby is the experimentation for me.
08-26-2023, 07:47 PM | #6 |
Re: Spark Gap
