Old 07-12-2018, 09:06 AM   #1
jetmek
Default 26/27block
Got one here with the knock out between ctr cylinders never removed. How exactly does one run throttle rod over to carb? Is it some kind of industrial engine? Just need to know if i have to open that up. Thnx
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 07-12-2018, 11:14 AM   #2
Jack Innes
Jack Innes's Avatar
Default Re: 26/27block
The later style carb. had the rod across the top of the engine so the hole was not necessary;
Jack Innes, Brooklin, Ontario
Jack Innes is offline   Reply With Quote
Old 07-12-2018, 12:40 PM   #3
jetmek
Thank you!
Old 07-12-2018, 07:50 PM   #4
39portlander
39portlander's Avatar
Jack I like that oiler and mount you have on the fire wall, is it possible you could post a few close ups of your set up thanks. Scott
39portlander is offline   Reply With Quote
Old 07-12-2018, 10:52 PM   #5
Jack Innes
Jack Innes's Avatar
Sorry, the picture is not my car. It was just used to illustrate the carb. linkage.
Jack
Old 07-13-2018, 12:03 AM   #6
redmodelt
redmodelt's Avatar
the oiler is just a standard one, you can buy the base/holder from the suppliers.
Old 07-13-2018, 11:08 AM   #7
nhusa
nhusa's Avatar
Lang's has a conversion kit #6299CL
Don't forget to get the clamp on throttle rod leaver # 6297
nhusa is offline   Reply With Quote
