Old 04-25-2016, 04:34 PM   #1
grantsauder
grantsauder's Avatar
Default NOS Headlight Reflectors
I have a set of 1930-31 NOS two light headlight reflectors that have been in my cupboard for 30 years. They have some hazing on the silver reflector and I would like to know how to polish them before I can install them in my refurbished stainless steel headlamp buckets. I am hoping to get my 1930 Tudor on the road this fall. Thanks. Grant
grantsauder is offline   Reply With Quote
Old 04-25-2016, 05:53 PM   #2
Dollar Bill
Dollar Bill's Avatar
Default Re: NOS Headlight Reflectors
Any silver polish will suffice. Being silver, they will soon tarnish again. That is reason for the newer reflectors that don't.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 04-25-2016, 05:59 PM   #3
Kevin in NJ
The easy way:
Removing silver tarnish
You need to be careful which gasket you use. A cork gasket is what you want. The rubber type will off gas and cause tarnish rapidly.
Kevin in NJ is offline   Reply With Quote
Old 04-25-2016, 09:59 PM   #4
700rpm
700rpm's Avatar
For some reason my original silver reflectors haven't tarnished in over 50 years on my Tudor, 10 years on my truck, or 5 years on my coupe. Just lucky?
Ray Horton, Portland, OR
Old 04-26-2016, 05:51 AM   #5
Steve Wastler
Steve Wastler's Avatar
The original reflectors on my fordor haven't tarnished much since new. Remember if you must polish, using silver polish always rub in a straight line edge to center.....
Steve Wastler is offline   Reply With Quote
Old 04-26-2016, 10:33 AM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Since the Silver plating is so THIN, I only wipe them gently, with a damp Chamois, use the smoother side.
A SHAMOIS is great for filtering GAS & it collects the water, also. Just wring it out, to remove the water. RECOMEMBER, OLD gas is a common problem for poor running & hard starting!!!!
Bill Bright
"THE ASSISTANT GURU OF STUFF"
Old 04-26-2016, 10:49 AM   #7
TinCup
TinCup's Avatar
I tried to polish some " Made In Argentina" reflectors that were still wrapped in paper but were tarnished. I used a silver polish and the silver came off with the polish. Test an edge and make sure the polish won't damage the plating.
TinCup is offline   Reply With Quote
Old 04-26-2016, 01:00 PM   #8
rocket1
lamp black,what ever that is
rocket1 is offline   Reply With Quote
Old 04-26-2016, 01:06 PM   #9
Jeff/Illinois
Jeff/Illinois's Avatar
Magic Wadding Polish and go lightly. Has worked well for me.
Jeff/Illinois is offline   Reply With Quote
Old 04-26-2016, 03:52 PM   #10
Dollar Bill
Lamp Black is a black carbon pigment made from soot. It forms the basis of the best traditional black inks and has been used to many other ends from shoe polish to blackening gun sights. Not anything that I think would help with polishing silver.
Old 04-27-2016, 08:28 PM   #11
grantsauder
Thanks to all you guys . I'll take the info and let you all know how they turned
out. I also found a set of South American reflectors and they will need a polish also . Thanks again. Grant
Old 04-28-2016, 05:01 PM   #12
rocket1
Henry states in the service bulletins wipe the reflector with dry lampblack,I knew that I read it somewhere!
Old 04-28-2016, 05:34 PM   #13
Charlie Stephens
How about a few close ups of the reflectors just to make sure they are NOS and not NORS from Argentina. If you need reflectors Bratton's has the best ones (and I don't think anyone else handles them).
Charlie Stephens
Old 04-28-2016, 08:40 PM   #14
RonC
RonC's Avatar
The Brattons reflectors are better than the originals if your driving at night
RonC is offline   Reply With Quote
