Old 04-12-2016, 07:23 PM   #1
Randy1944
Randy1944's Avatar
Default 39 Pickup wiring
Another update on the wiring. Got the wiring fixed so the dash lights burn and the switch box on the back of the steering column works as well. When we got done, we realized that the battery is not being charged. We will have to work on that in the next few days. It sure is nice to have the truck running without having to hot wire it.
I am really pleased with the motor that was last driven in 1984(last license tag dated) in Calif. Now it is on the roads of east Tn.
Thanks to all who have got me this far. Especially "Seery"
Randy
Randy1944 is offline   Reply With Quote
Old 04-12-2016, 08:52 PM   #2
JSeery
JSeery's Avatar
Default Re: 39 Pickup wiring
If the generator is putting out power and is connected to the same post on the fuse panel as the main lead from the battery it should be charging. Any idea on the condition of the generator?
Old 04-12-2016, 08:58 PM   #3
Randy1944
Randy1944's Avatar
The generator is the one that came with the truck. We did open it up and put new brushes in and cleaned it up mostly. It very well may turn out to be the problem. I will let you know.
Thanks
Randy
Old 04-13-2016, 06:54 AM   #4
SofaKing
SofaKing's Avatar
It is recommended to "flash" the generator after rework, long periods or dormancy, etc or it may not have correct polarity and hence no output.
SofaKing is offline   Reply With Quote
