Old 11-21-2023, 12:59 AM   #1
Brian
Brian's Avatar
Default Frenzel
What do you guys think?
https://www.frenzelsupercharger.com/
Old 11-21-2023, 01:48 AM   #2
kiwi nz
Default Re: Frenzel
Yes please.
kiwi nz is offline   Reply With Quote
Old 11-21-2023, 01:53 AM   #3
petehoovie
petehoovie's Avatar
Default Re: Frenzel
Old 11-21-2023, 08:24 AM   #4
Terry,OH
Terry,OH's Avatar
Default Re: Frenzel
very nice
Old 11-21-2023, 09:07 AM   #5
36and63
36and63's Avatar
Default Re: Frenzel
Check this video out
https://www.youtube.com/watch?v=zLEC...cmNoYXJnZXI%3D
Pat
36and63 is offline   Reply With Quote
Old 11-21-2023, 09:16 AM   #6
hotrodcbx
Default Re: Frenzel
Judging by the pulley sizing I see, it appears this centrifigal blower operates at about 50% over engine speed. A ratio of 1 to 1.5. Seems low until I noticed there is a gear driven overdrive on the blower blower housing.
hotrodcbx is offline   Reply With Quote
Old 11-21-2023, 10:29 AM   #7
Automotive Stud
Automotive Stud's Avatar
Default Re: Frenzel
Scott looks cooler IMO, but I probably won't be buying either one any time soon.
Automotive Stud is offline   Reply With Quote
Old 11-21-2023, 10:33 AM   #8
GB SISSON
GB SISSON's Avatar
Default Re: Frenzel
Sooo cool. Total loss battery ignition? I don't see a mag.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 11-21-2023, 12:31 PM   #9
tubman
tubman's Avatar
Default Re: Frenzel
It seems the Aussies are still ahead of us for cool flathead stuff.
Old 11-21-2023, 01:32 PM   #10
hotcoupe
hotcoupe's Avatar
Default Re: Frenzel
I think the Frenzel is cool as can be, sometime ago I looked into purchasing one. If I remember correctly they were priced around $10,000.00, there is also one being made in the states. My biggest question was, how do you drive the generator?
Tom
hotcoupe is offline   Reply With Quote
Old 11-21-2023, 01:53 PM   #11
Newc
Newc's Avatar
Default Re: Frenzel
So why only ONE drive belt?? When are we to see a TRIPLE crankshaft pulley from someone? Even an old McCucllic [?]needs a better crankshaft pulley. Newc
Old 11-21-2023, 05:03 PM   #12
itslow
itslow's Avatar
Default Re: Frenzel
Aaron Loveless is also reproducing them here in the US.
https://frenzelsuperchargers.com/
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 11-21-2023, 11:38 PM   #13
Newc
Newc's Avatar
Default Re: Frenzel
Here is a photo of a 'Cyclone' -similar set up in a collection in Oregon. Newc
Old 11-22-2023, 12:37 AM   #14
ford38v8
ford38v8's Avatar
Default Re: Frenzel
I know nothing about blowers, and not much more about anything else, but please tell me why the starter is on the left side? I know the picture is not reversed, because I can at least spell Frenzel.
Alan
Old 11-22-2023, 01:17 AM   #15
Brian
Brian's Avatar
Default Re: Frenzel
1954 Canadian flatties had the starter on that side. Finally, changing a starter motor in a RHD car is much simplified...lol Yes, Ford Canada kept the flathead one year longer than USA
Old 11-22-2023, 01:51 AM   #16
petehoovie
petehoovie's Avatar
Default Re: Frenzel
Old 11-22-2023, 06:57 AM   #17
solidaxle
solidaxle's Avatar
Default Re: Frenzel
Looks like a stock 8ba crank pulley. I would bet it's a work in progress. Looking at the pictures he has some clearance issues to work out.
The distributor looks like it's in the way of using the back sheaves on the upper pulley.This can be over come by the use of a Chevy dissy that the base stands roughly an inch taller and will probably still a need an idler to pull it away even more.
Depending what car it's going in, the water pump hoses will be close to belts.
He probably needs to fab both pulleys.
solidaxle is offline   Reply With Quote
Old 11-22-2023, 07:25 AM   #18
solidaxle
solidaxle's Avatar
Default Re: Frenzel
The vacuum distributor he has maybe the best option.
I have a Malloy flat top with mechanical weights and have been considering using a vacuum advance distributor on my S.c.o.t. setup. Reason being, once you stomp on it, the timing will momentarily retard do to lack of vacuum, helping with detonation until the rpm's increase.
Old 11-22-2023, 08:15 AM   #19
corvette8n
corvette8n's Avatar
Default Re: Frenzel
Cool looking blower, but it doesn’t look like it would fit under the hood of many cars.
Old 11-22-2023, 08:24 AM   #20
GB SISSON
GB SISSON's Avatar
Default Re: Frenzel
With my 'total loss ignition' comment, I was referring to the fact that it did not have a means to recharge the battery.
