03-14-2015, 01:06 PM | #1 |
Quick Flathead question for everyone
Will a T5 transmission for a ford (unknown year) work on a 8BA Flathead. Seems what i have been reading is the S10 T5 is the go to choice.
Thanks in advance for everyones help |
03-14-2015, 01:36 PM | #2 |
Re: Quick Flathead question for everyone
I believe that the difference is the location of the shifting mechanism. The S10 is farther forward than the mustang type.
03-14-2015, 01:48 PM | #3 |
The late '80s/early '90s Mustang W/C T-5 is a better choice over an S-10 because of better ratios, internal improvements and higher strength, but the S-10 tail housing swap moves the shifter forward and next to the gear box. A 1" adapter will mate the trans to any '49-'53 Ford/'51-'53 Mercury bell housing.
03-14-2015, 04:22 PM | #4 | |
First photo is an aftermarket cast adapter Second photo is half-bell, hogshead & 1 inch plate adapter Third photo is line drawing using a half-bell and aftermarket cast adapter Forth photo is half-bell, hogshead, 1 inch plate adapter & S10 T5 |
03-14-2015, 04:34 PM | #5 |
Hi..i'm in the way to put Ford t5 on my potvin powered flathead,,and i see that there are other ways to put the shift level forward,,,a remote lever mechanism is the right way,in a mustang web page there is one type for sale....other easy way i try is to buy a opel corsa c shift lever.....or at least is not really difficult to build one yourself......
03-14-2015, 07:39 PM | #6 | |
03-14-2015, 08:44 PM | #7 |
Definitely go for the late model Mustang. Better ratios and MANY improvements over the S-10.. I have used the 1" adapter plate but for my current build I am using a Quick Time bellhousing from Speedway Motors. Not cheap ($570.00) but I believe it will hold the critical engine to trans alignment more accurately..
03-14-2015, 08:54 PM | #8 | |
I like the remote shifter using the original shifter location and shifter. That's what I am using with a Ford T5z transmission. Last edited by JSeery; 03-14-2015 at 09:14 PM. |
03-14-2015, 09:45 PM | #9 |
I think this is what was meant by a remote lever
'52 F-1, EAB flathead |
03-14-2015, 09:49 PM | #10 |
V8 Bob
Where did you get that adapter, I've been making them, but this is a better and cheaper way to go |
03-15-2015, 07:34 AM | #11 | |
http://www.safepay.net/cgi-bin/shop/...oderndriveline |
03-15-2015, 11:16 AM | #12 | |
03-15-2015, 11:46 AM | #13 | |
A few early '51s used the '49-'50 stamped steel 1/2 bell and round patterned transmissions. |
03-15-2015, 02:48 PM | #14 |
That adapter works with the 49-53 Ford and Mid 51 merc bell housings using all stock parts except the disk.
03-15-2015, 03:00 PM | #15 |
I had never seen one, didn't know they existed! Thanks.
