05-19-2012, 03:59 PM | #1 |
Ford Script 600x16 Tire ID
Anyone have an idea what type of tires these are and for?
05-19-2012, 04:21 PM | #2 |
Re: Ford Script 600x16 Tire ID
Is this a trick question?
If they are authentic (very doubtful) they are FORD tires, manufactured by Ford. Intended to be primarily installed on Ford products, mostly passenger cars, 1937 - 1948. Much more likely they are more recent reproductions made by one of the major tire manufactures (Firestone and / or Goodyear) for the after-market consumer.
05-19-2012, 05:10 PM | #3 |
Kube, not a trick question.
I have not seen a set like this before, thus my question. I'm trying to find out if they are Ford or repop and if repop who is/was selling them. Last edited by 2935ford; 05-05-2013 at 08:24 AM. |
05-19-2012, 05:22 PM | #4 |
Look at the very small words on the tires. "Newer" tires have date codes as well as highway safety ratings. If those are on there, they are newer "repops".
Also, look at the construction content... that will be on there as well. If you find "nylon" as one of the contents, the tires are "newer" repops.
05-19-2012, 05:53 PM | #5 |
Kube, thanks, I'll have a look.
05-19-2012, 06:17 PM | #6 |
05-19-2012, 06:21 PM | #7 |
Says 4 ply polyester with DOT DYWM and some load rating.
05-19-2012, 06:57 PM | #8 |
In that case they are later replacement tires. New, these run about $160 each if I recall correctly.
05-19-2012, 07:00 PM | #9 |
I have a set of Ford ww on my 35 made by universal tire co.
DON P |
05-19-2012, 07:06 PM | #10 |
Thank you.
01-23-2013, 09:44 PM | #11 |
Do you want to sell them Gord sympatico.ca 705 924 1702 Ontario
