12-15-2016, 09:30 PM | #21 |
Re: Kingpins
My machine shop hones them,,, i was not there
My king pins are round. Last edited by Mitch//pa; 12-15-2016 at 09:38 PM. |
12-15-2016, 09:44 PM | #22 |
Re: Kingpins
Don't leave the bushes too tight hoping that you will get more life out of them. The steering will be stiff and the car will wander all over the road.
Don't overt tighten the cotter pins (I think you guys call them tapered lock pins) that hold the king pin in the axle eye. I have seen that done and the eye was stretched oval. It's impossible to not have a wobbly wheel it that happens without shrinking the eye again and not many places will even try that. As for oversized king pins, if they are oversized, they won't fit through the eye of the axle.
12-15-2016, 09:49 PM | #23 |
Re: Kingpins
Do hone them. King pins can vary in the same set, not by much a few tenths but with
honing you get them spot on. They also vary some from brand to brand. Don't just use the non adjustable reamer. My 2 cents. |
12-16-2016, 09:57 AM | #24 |
Re: Kingpins
Possibly the last comment about reamers, remove only one bushing, then install the new bushing and ream it. If the opposite bushing is removed, the guiding plug at the end of the reamer would be a very sloppy fit for the Alignment Plug that guides the reamer. After reaming the first hole, then replace the second bushing and ream it. The Sunnen hone sizes both bushings at the same time - perfectly aligned and sized for clearance to match the size of the spindle bolt.
12-16-2016, 01:25 PM | #25 |
Re: Kingpins
Nothing like an old thread coming back to life.
The original thread was last posted to in 2010!! |
12-17-2016, 04:12 PM | #26 |
Re: Kingpins
Supergnat Last edited by supergnat; 12-17-2016 at 04:13 PM. Reason: Correct spelling error |
12-26-2016, 09:59 PM | #27 |
Re: Kingpins
12-26-2016, 10:08 PM | #28 | |
Re: Kingpins
http://speedequipcorp.com/home.html |
12-26-2016, 10:27 PM | #29 |
Re: Kingpins
Thanks Mitch!
12-26-2016, 10:52 PM | #30 |
Re: Kingpins
Call Tom Jordan at Snyders. He will walk you though the proper sequence.
Good enough.. Isn't. |
