03-22-2011, 04:58 AM | #81 | |
Re: Not getting fire!! Won't start. PLEASE HELP FAST!!
Once you figure this out you need to move on to the running. Sounds like fuel starvation. I would disconnect the fuel line and make sure you have a good stream of fuel to the carb for as long as it takes to fill a quart jar without any fluctuation. If the fuel is intermittent or stops, use a compressor to blow back into the tank from the carb end. If the flow is good, remove the carb and clean it out. It may have rust sediment in the bowl. These are my only suggestions without seeing the car. |
03-22-2011, 07:16 AM | #82 |
03-22-2011, 07:55 AM | #83 |
If you have a good strong spark to the points, the only things between them and the plugs is the rotor, the distributor cap and the distributor body. I'd change those and double check the timing and gaps.
03-22-2011, 08:48 AM | #84 |
To address the running issue, try doing a compression test to see if you maybe have a stuck valve. I had a stuck valve one time and it would start, idle, but would stumble and not run well under any kind of driving situation. If the car had sat for a little while perhaps one stuck open.
03-22-2011, 12:37 PM | #85 |
Confusion in TERMS.
It's been mentioned a few times during this thread about getting "good spark at the points". Actually I hope they meant getting good spark to the rotor, because one job of the condeser is to keep arcing down to a minimum at the points. |
03-22-2011, 01:07 PM | #86 |
(just being a smart azz) |
03-22-2011, 02:25 PM | #87 |
03-22-2011, 02:39 PM | #88 |
do you have vacuam to suck the gas in the engine.
03-22-2011, 03:26 PM | #89 |
I found one thing about mine when bought it not running, until I got the timing "right" they can sure run funny.
03-22-2011, 04:28 PM | #90 |
So true!!!!
03-22-2011, 04:57 PM | #91 |
Hey Tom W. sorry to get off the main subject, but a friend was having a problem with his distributor and when we had the rotor off we watched the points open and close the spark would get real bright sometimes and dim other times. Would this mean the condenser is going bad? The points are the modern type with the condenser on the top plate. The motor was running rough and the #3 spark plug was not firing. We changed the distributor to another and the engine runs great. Dose a condenser go bad slowly or just quit?
Model A Ford Club of New Jersey http://www.mafcnj.org Model A Pick Up Owners and Enthusiasts http://www.fordbarn.com/forum/group.php?groupid=5 |
03-22-2011, 05:25 PM | #92 |
Ed,
The condenser can fail slowly, or all at once. I don't ever recall having one fail in any car I've ever driven. Of course it was pretty standard to change plugs, points, and condenser every 10,000 miles. I quit doing that a long time ago, and now only replace bad parts. |
03-22-2011, 06:31 PM | #93 |
Or gullet.
A feller here recently bought an amazing original T-motor sprint car with GEMSA head and all kinds of authentic old goodies on it. Supposedly he got it cheap from some young guys who were "mechanics" at a repair shop - they could get it to idle but nothing else. Once the red mechanic's rag was pulled out of the intake manifold, it ran great. I suppose he will tell the sellers about it someday. |
03-22-2011, 07:20 PM | #94 | |
1. Have the new condenser laying next to the distributor. 2. From the passenger side, remove the ground screw first. 3. From the driver's side, remove the terminal screw and keep light pressure on the screw while you slip out the old condenser and slip in the new one. 4. Tighten the terminal screw. 5. Tighten the ground screw. |
03-22-2011, 07:40 PM | #95 | |
03-22-2011, 09:25 PM | #96 |
I had the center contact on the rotor cap disintegrate. I shut it down one night and it wouldn't start the next morning. No fire to the plugs. Took forever to figure it out. New cap did the trick. Good luck.
03-22-2011, 10:45 PM | #97 |
I think it is the thermalgockle probably clogged.
03-23-2011, 10:58 AM | #98 |
It only takes a minute or two to change the condeser following this proceedure:
1. Have the new condenser laying next to the distributor. 2. From the passenger side, remove the ground screw first. 3. From the driver's side, remove the terminal screw and keep light pressure on the screw while you slip out the old condenser and slip in the new one. 4. Tighten the terminal screw. 5. Tighten the ground screw. Tom Wesenberg, thanks for great tip in #3. I can not tell you how many times I have dropped the terminal screw and had difficulty getting a new one started. I can not wait to try your procedure. Thanks for another bit of great advice. |
03-23-2011, 02:28 PM | #99 |
is this car running yet
03-23-2011, 03:34 PM | #100 | |
