08-13-2022, 05:59 PM | #1 |
Seat Springs
Anyone that has replaced their seat springs can you give me your opinion?
Just received a set of front seat springs for my Blindback. Any advantage of painting them prior to upholstery.
I don't care if the "A" Starts BUT sure WANT IT TO STOP! |
08-13-2022, 09:08 PM | #2 |
Re: Seat Springs
I made a front spring out of a old bed spring and election sign wire. It came out pretty damn good. I would put it up against any original spring. The only difference is mine has smaller coils and that makes it a little firmer. People weigh more now. You would need a welder to make what I made. If you're considering trying one too. I noticed that every original spring I saw was rusty, some very much rusty and some not so much, but all were rusty. So I painted the ones I made with a "rust Paint" like Ben Moore's "Rust scat" This does the trick very nicely. Try to stack two or more springs and spray downward. Shift them a few times to get coverage and I think they will be fine.
Terry |
08-14-2022, 12:19 AM | #3 |
Re: Seat Springs
Paint is a good way to stave off corrosion. Iron oxide can bleed through lighter colored fabric if the seat gets wet. It's always a good idea to paint the spring boxes.
08-14-2022, 12:49 PM | #4 |
Re: Seat Springs
Thanks to you BOTH for your suggestions!
08-14-2022, 01:10 PM | #5 |
Re: Seat Springs
"The more things change, the more they stay the same." |
