Old 07-29-2010, 05:25 PM   #1
abbie
Default Rocky Mountain Brakes-Hassler shocks
I own a 1923 Model T . I recently toured with a group in Ohio and came to the conclusion I should consider secondary brakes. I ordered Rocky Mountain- I started putting them on this morning and reading the instructions; the second sentence says, "Hassler shocks can not be used with the additional brakes". I have these shocks on the car. Two part question, is there a modification to use both that is available????? If not; which would you prefer?? After seeing they will not go on I contacted Langs and ordered emergency brake shoes with lining, the ones on the car had no lining. Emergency brakes shoes with lining would help in an pinch, but only a little. All suggestions appreciated.
abbie is offline   Reply With Quote
Old 07-29-2010, 10:49 PM   #2
jackdaron
Default Re: Rocky Mountain Brakes-Hassler shocks
The RM's will fit with the pancake Hasslers,but they are getting harder to find.
jackdaron is offline   Reply With Quote
Old 07-30-2010, 07:49 AM   #3
abbie
I wonder if the larger drum, 26-27, would fit over the shocks???
Old 07-30-2010, 08:36 AM   #4
Jack Innes
Jack Innes's Avatar
Have you seen AC brakes? They fit on the outside of the standard small Ford drums. There should not be a clearance problem with them. They are available at about $325 There is a picture of them at larrysoldies.com .
Jack Innes is offline   Reply With Quote
Old 07-30-2010, 09:43 AM   #5
abbie
Jack-Thanks for the information. I looked it up and I agree; they should clear. I will contact him, probably send a picture and get his thoughts. Have a good summer.
Abbie
