Old 06-22-2022, 10:52 PM   #1
1930artdeco
1930artdeco's Avatar
Default Sun dist tester
Hi all,
I just grabbed this tester and discovered it is from 46. Will I be able to use it on my 57 dist?
Mike
File Type: jpg CCCBDD57-0189-4710-9202-D75C50971BE2.jpg (44.9 KB, 32 views)
1930 TownSedan (Briggs)
1957 Country Sedan
Old 06-23-2022, 12:20 AM   #2
miker98038
miker98038's Avatar
Default Re: Sun dist tester
Probably. Close up of the gauges would help. Big deal (here at least) would be if it also worked on a loadomatic. Didn’t flatheads use those then? Or later? Cool find.
miker98038 is offline   Reply With Quote
Old 06-23-2022, 02:34 PM   #3
Gene F
Gene F's Avatar
I am not buying any more of these test sets. Everytime I buy one it supposedly works. And it does not. No one will fix them either. 1 charging and starting, and 2 scopes. I trashed 'em. Tons of honest rip-off artists.
Old 06-23-2022, 03:26 PM   #4
1930artdeco
Here are the gauges. The unit was made in 45/46.
File Type: jpg 07512367-CC12-443E-8128-87F4E5E85C99.jpg (66.5 KB, 23 views)
1957 Country Sedan
Old 06-23-2022, 07:49 PM   #5
miker98038
miker98038's Avatar
Dwell, vacumn and distributor rpm is a good start. Someone one here is going to know if it shows an advance curve (missing attachments?). But just being able spin it up and make sure the dwell is stable tells valuable info out wobble etc. Someone will know, I’m sure. If not I’ll take the pictures down to the guy I know with a machine and get his take on it.
Old 06-23-2022, 08:14 PM   #6
1930artdeco
I have paperwork from Sun that goes up to 53. So beyond that I am not sure. It will end up getting a full resto in the end. I am not sure how to even use the thing. But it looks like all the pieces are there.
Mike
1957 Country Sedan
Old 06-23-2022, 10:42 PM   #7
1930artdeco
Well did some did some dusting and found some things good and bad. First off, found out the wiring is all Mickey moused up; second, I found one of the side panels; third I found out the strobe is missing. So the machine may be garage art until I can replace it.
Mike
File Type: jpeg 312F3EED-AA5C-44BD-9898-BEA990F09B84.jpeg (131.5 KB, 9 views)
File Type: jpeg AF33610D-CE5F-4227-8572-110778164BFD.jpeg (119.9 KB, 10 views)
1957 Country Sedan
Old 06-24-2022, 12:57 AM   #8
fordcragar
fordcragar's Avatar
You might contact these guys for help/repair on the Sun machine:
http://www.paramountd.com/repair.html
fordcragar is offline   Reply With Quote
