06-02-2020, 12:15 AM | #1 |
29 sport coupe windlace
I looked thru a bunch of the windlace posts and one made mention of the rivits that hold the windlace cover on the A pillar, this car had # 8 machine screws and nuts holding the metal cover on, that didn't seem right and the top 3 on each side under the A pillar cover were missing so I'm thinking that those must have been threaded to # 8 machine so I retapped to # 10 so now I think I'm wrong all the way around, so the small split rivits are what holds the cover to the pillar will they squeeze tight enough to keep the cover from squirming around on the pillar.
Thanks Aaron |
06-02-2020, 10:29 AM | #2 |
Re: 29 sport coupe windlace
Aaron, originally windlace (A-50394 Coupe Pillar Windlace) was installed along with a brown paper cover (A-45376) which wrapped the windlace after it was installed to keep the windlace from being covered with paint overspray during painting. The vertical metal Retainer was installed with 5/32nds Tubular Rivets which ultimately was painted body color.
06-03-2020, 08:33 AM | #3 |
Thanks Brent, I kinda wondered about the painting part but I was guessing the old style brass split rivits and they would not show up too much if put on after painting, what came with the kit was stainless, so everything came apart and those got put in, another lesson learned.
06-03-2020, 09:02 AM | #4 |
Great info Brent. Makes sence when you think about it, that they covered the windlace and installed it before painting. Where did you find that great info? John
06-03-2020, 09:47 AM | #5 | |
As for the process, I write down topics I want to research on an excel spreadsheet so that I can remember them when i get there. I begin my list by using the part number of the assembly drawing that I typically see in the original Parts Books. Only after the assembly drawing is found will it list the part numbers for the components used in the assembly. Sometimes those components will be sub-assemblies that you break-down the components list even further. A good example would be a Generator. When you look at the A-10000-B Generator Assy, it will list all the components including parts like the A-10005 Generator Armature. Once you look up that drawing, you will see other sub-items such as the Insulators, Insulation, Spider, the A-10010 Armature Core, etc. Then those might even be broken down further with Foundry drawings and then Machine Shop drawing. Each has its own info. for each department or supplier. On each of these prints, there typically is EI (-Engineer's Information) numbers listed at the top right of the drawing that allow you to pull those EI sheets for explanation of the drawing or procedure. This in a nutshell is why it is so difficult to do research outside of the library. I hope this answered your question John. |
06-03-2020, 06:37 PM | #6 |
06-04-2020, 08:06 AM | #7 | |
