Old 08-30-2019, 04:12 AM   #1
shew01
shew01's Avatar
Default Zero Grease Fitting Replacement
I bought a set of replacement Zerk grease fittings from Bratton’s. Some of the old fittings look pressed in. What is the easiest way to remove them without breaking the old fittings?
Old 08-30-2019, 05:26 AM   #2
Steve Plucker
Default Re: Zero Grease Fitting Replacement
A small chisel and hammer...work your way around the zerk...it will soon come out.
Pluck
Old 08-30-2019, 08:03 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
Visegrip pliers.
Bob Bidonde
Old 08-30-2019, 09:35 AM   #4
Anteek29
Anteek29's Avatar
Vicegrips...clamp, twist and pull. (My dentist does it best)
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 08-31-2019, 04:00 PM   #5
CarlG
CarlG's Avatar
As others have said, like removing a tooth - vice grips and rock it back and forth while pulling.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-31-2019, 04:37 PM   #6
john in illinois
john in illinois's Avatar
I recently replaced the fittings in a pair of spindles. I had a terrible time instaling the push in fittings. I think they were too large diameter. Repro parts.
I hab done it about 10 years ago and I do not remember it being that hard. You will need the special tool to drive them in.
The holes are too big to tap 1/8 pipe for screw ins.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 08-31-2019, 08:05 PM   #7
Cape Codder
Cape Codder's Avatar
Well, I have do ask, do they require anesthetic?
Cape Codder is offline   Reply With Quote
