Old 03-07-2014, 09:32 PM   #1
sphanna
sphanna's Avatar
Default Arvin heater update
Some ov you have requested photos and updates on the Arvin heater installation. I finished installing it today except That I am not happy with the placement and wiring for the speed control of the blower. I temporarily installed heater so you could get the idea. I will lean up switch location and wiring later.
The first pix how I cut the floor board so as to be able to service battery without disturbing the heater mount.
The second picture shows the strap I used to strengthen the left board. A similar strap is under the right board. The straps tabs fit under the forward board and I drilled and tapped them so I can bolt them through the upper board.
The third pix shows the left board from the top (note the tapped hole for the small bolt).
The fourth pix shows the boards and the heater bolted to the floor. The gear shift looks like it hits the heater in low gear but it does not.
The last pix is as installed. The thing on top is the speed control rheostat. This will be relocated for appearence sake.
Look at the MARC Jan/Feb 2014 Model A News mag for Charles Beckman's article on this. Thank you Charles.
Now I have heat for Winter and A/C for Summer. I like to.tour in comfort. Next I am installing a flathead Ted's deluxe kit.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 03-07-2014, 09:36 PM   #2
sphanna
sphanna's Avatar
Default Re: Arvin heater update
I'sorry, I am having trouble posting pictures. Can only get one. Anyway that's what it looks like. I'll keep trying. Maybe I have to load them one at time.
Old 03-07-2014, 09:40 PM   #3
QGolden
QGolden's Avatar
That is a good spot for it. Looks like the shifter is hitting it, but that may be a camera angle?
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 03-07-2014, 10:17 PM   #4
sphanna
sphanna's Avatar
No, the shift does no hit the heater. Read the text on one of other posts.
