06-21-2019, 11:40 AM | #1 |
Preserving left over urethane paint
Opened a can of left over bambalino blue Restoration Shop urethane paint from my 36 woodie yesterday. I had filled the gallon can which was half full with wire feed welding gas. Sure enough there was no hardened layer of paint on the surface. It looked like I had just opened a new can of paint. Anyone else try this?
41 woodie https://41fordwoodie.weebly.com/ |
06-21-2019, 11:47 AM | #2 |
Re: Preserving left over urethane paint
A trick I use is to store used paint in cans upside down, it seems to work.
06-21-2019, 12:30 PM | #3 |
Just wondering what process you used to add the welding gas? Kind of reminds me of when I first started to work in a bodyshop. The boss told me to get him a bucket of compressed air...Sorry, I couldn't resist the comparison.. Bill
06-21-2019, 02:23 PM | #4 |
Is this "urethane" a two component (2K) product (needs hardener) or a one component (1K)? A 2K typically will not form a film inside a sealed container since the hardener (once added) produces the cure. I've stored both pigmented and clear 2K urethane for 15 or so years with no effect except clear may be slightly yellower than when new. The hardener is what can go bad. Hardener is packaged in an envelope of inert gas to keep moisture away. Once opened humid air enters and can slowly react with the isocyanate and become "seedy" or completely solidify.
06-21-2019, 03:06 PM | #5 |
Glass marbles....
06-21-2019, 04:03 PM | #6 |
Vic |
06-21-2019, 06:26 PM | #7 |
Ya! guess that in Alaska you put it in the refrigerator to keep it warm.
06-21-2019, 06:48 PM | #8 |
06-21-2019, 07:28 PM | #9 |
For 60 years (I am 80) I have always flooded paint, varnish, urethane cans with my propane torch gas and then quickly put the lid on. Never a skin. Latex paint doesn't need it.
06-22-2019, 01:00 AM | #10 |
Correction. It got 90 to degrees in Fairbanks today. You are correct. We sometimes put stuff in the refrigerator to prevent from freezing.
Vic Last edited by Vics Stuff; 06-22-2019 at 01:12 AM. |
06-22-2019, 03:23 AM | #11 |
huge fart.
06-22-2019, 09:46 AM | #12 |
All I know is it was miserable working in the heat! I can’t believe I grew up in south Texas, I can’t stand the heat anymore! Give me 35-40 degrees and I’m comfortable.
Back on paint, I have put Saran Wrap over the can, then put the lid on. Works good, especially for POR. |
06-22-2019, 10:14 AM | #13 |
Regarding, "Back on paint, I have put Saran Wrap over the can, then put the lid on. Works good, especially for POR."
I've used screw lid mason jars, putting a double film of Saran Wrap over the opening before closing. After about a year or so though, it still gets hard especially if the jar is only filled part way. Maybe I'll try propane gas next time. Seems like a good idea. |
06-22-2019, 10:50 AM | #14 |
06-22-2019, 11:37 AM | #15 |
Mig gas works great, never a problem. But in some situations I'll food wrap it as well.
06-22-2019, 04:31 PM | #16 |
I take it you don't smoke? Boom!
06-22-2019, 08:11 PM | #17 |
06-23-2019, 10:15 PM | #18 |
when I bought our '41 ford in' 94 it was painted with original Lochaven Green. I bought a gallon of single stage about '95 or '96 and I still have it. In fact I used some about a month ago. Is perfectly fine
